How to upload Budget in epicor-Kinetic
I am trying to upload the 2024 budget in Epicor Kinetic version and could not find a way. Can someone share your thoughts on this?
Thank you
Reji
Use the DMT Budget upload template.
It’s a little complicated b/c of the format, but it works just fine.
You have “Import Budget” option under Action in Account Budget entry screen. It works fine.
Hi Rakesh,
Should I first export the budget template, then use to populate the data, then import the file in Epicor? Or shall I use an excel sheet to upload?
Hi Mike,
I am not familier about DMT template. Is it same as the export file format?
in looking at that import/export button - I would use that first. The file format in XLSX is much more intuitive than the DMT template (one account/period/amount per line). Enter a budget amount manually for one account, then Export it so you get a useable template in Excel. Fill it in and re-import.
The DMT is much better for multiple companies, super large budgets (or multiples) since it works in the background.
Thank you Mike for your direction.
Yes, you need template first. This is excel based template, use it to import back.
KR
Please mark this thread as solved for future users asking the same question.
Solved. Thank you
