I am looking for an APM expert setup resource. (re-posting) :-)
You usually end up needing help with the install if you do it on your own - going direct to APM (Altec) helps, not so sure about Epicor support on this.
Our company put a document<http://f1.grp.yahoofs.com/v1/0PO9UEjEY_6JYu0qbOWVLTPm9gN0QmvCBhLMER7RJRixSNIPMoiMKWgbnBLsKURXTXKt-MqujDoHnl7oyfSSJ1EFYSY/APM/APM%20setup%20document%20steps%20-%20new.doc> in the files section of this user group that walks you through setting up your documents to send them out. We send out several reports - SO Ack, PO, Invoice, Late Receipts, etc. The document covers sending from different mailboxes and different methods (print, email, fax).
Up to you if you want to go the consulting route or give it a try yourself.
