You can also turn off "Broadcast" in the TCP/IP settings for the network card on the Win95 PC's. This polls the network and can cause major system slowdowns
Regards,
David Sloan
IT Manager
Entech Integrated Technologies
Regards,
David Sloan
IT Manager
----- Original Message -----
Sent: Friday, May 11, 2001 3:19 AM
Subject: Re: [Vantage] If you're going to ver 5....
Try changing your network card to 10MBPS/Half Duplex. We
found that we had some cards that did not play well together with
our switch (Autonegotiating). Hard setting the card speed cleared
up the problem on machines we were having problems with.
Tim Care
Electro Chemical Finishing
To: <vantage@yahoogroups.com>
Sent: Thursday, May 10, 2001 12:33 PM
Subject: RE: [Vantage] If you're going to ver 5....
> Unfortunately that did not resolve my problem of a very very slow log on
to
> the new server. A clean machine connects no problem, all going through
the
> same hardware.
> Greg
> -----Original Message-----
> From: Britt Moelling [mailto:bmoelling@...]
> Sent: Thursday, May 10, 2001 12:08 PM
> I removed every reference which included "epicor". You do not need
> anything on the old path. I just removed the "default" key (on the right
> side) only.
> I had probably 10-15 references on each workstation.
> I would however backup the registry first.
> Britt Moelling
> Greg Gillette wrote:
> > In regards to removing the registry entries..
> > I did an uninstall of my progress client..
> > I ran an UNREGOCX file from Vantage Support..
> > I do a search of epicor and the first one I come across for example
> > is..
> > H
EY_CLASSES_ROOT\TypeLib\{3AA8042B-DF1C-11D3-B240-0004AC5B140B}\1.0\0\win32
> > Default \\poweredge\epicor\vantage\dll\progress IPC.OCX
> > Would that be one to remove? And everyone I come across as well?
> > There
> > seems to be a lot of these.
> > Sent: Thursday, May 10, 2001 10:49 AM
> > Thad
> > The problem is that I did remove the progress client first, but the
> > uninstall doesn't remove all the registry entries.
> > For ver 3, I think the "share" dir was "dwc"
> > Ver 4 used "epicor" as the share dir.
> > Thad Jacobs wrote:
> > > It may be more practical to remove the old 3.0 client and progress
> > 8.3
> > > install first, before upgrading, so you don't have to sort between
> > > versions
> > > in the registry.
> > > On my version 3 client install, there is no reference to "epicor",
> > so
> > > searching for "vantage" in REGEDIT would be better. MAKE SURE TO
> > MAKE
> > > A
> > > BACKUP OF THE REGISTRY before going through and deleting all the
> > > "Vantage"
> > > keys. There is no undo in REGEDIT.
> > > From: Troy Funte [mailto:tfunte@...]
> > > Sent: Wednesday, May 09, 2001 2:11 PM
> > > Britt,
> > > Would you say the same thing goes for Vantage 3 and 5 being on
> > the
> > > same
> > > machines? We can't help but do that right now as we are testing,
> > but
> > > I
> > > would love to know any details about removing every trace of 3.0
> > (and
> > > progress 8.3) off our workstations after the migration to 5.0.
> > > Troy
> > > Sent: Wednesday, May 09, 2001 2:13 PM
> > > Subject: [Vantage] If you're going to ver 5....
> > > If you're going to ver 5, be sure and do the following:
> > > 1. Do a database analysis FIRST, and if your "scatter factor"
> > is
> > > too
> > > high, do a "dump-and-load". Epicor does NOT have a
> > "dump-and-load"
> > > for
> > > ver 5 ready yet!
> > > ( I wish I had known this BEFORE we went to ver 5)
> > > 2. Un-install Progress 9.0 from every workstation. Then go
> > > into"
> > > regedit", and delete all references to the "epicor" directory.
> > > 3. Clear out the vntgwork directories
> > > 4. Reboot and install Progress 9.1A & Vantage
> > > .... and don't put both Vantage 4 & 5 on the same
> > > workstation!!!!!!!!!!!! I tried, and had to Norton's CleanSweep
> > to
> > > remove both of them!
> > > Britt Moelling
> > > M&M Manufacturing Co.
> > > Yahoo! Groups Sponsor
> > >snip<
