[Tech] Half/Full Duplex - followup
You can also turn off "Broadcast" in the TCP/IP settings for the network card on the Win95 PC's. This polls the network and can cause major system slowdowns
Regards,
David Sloan
IT Manager
Entech Integrated Technologies
----- Original Message -----
Sent: Friday, May 11, 2001 2:11 AM
Subject: Re: [Vantage] [Tech] Half/Full Duplex - followup
Malcolm:
I'm telling you dude, try changing the workstation in question to Win 98 SE. I went through tons of crap, and did that last, on three data collection PCs and one office PC and had a great improvement!
Rick
Malcolm Spann wrote:
> As a followup to my earlier post:
> Server: The server is a NT4 SP6a server, using the same server
> name, IP address, OS and service patch as before. It's a P-III 700
> single processor with 512 Meg RAM. Vantage is the only
> application running on this server (well, there is the UPS software
> and the tape backup client). There is no virus software running on
> the server.
> Per Epicor's 'Performance Tuning Document', the server is getting a
> buffer pool hit rate of about 96% (it better be, with all that memory
> and no other applications running).
> Workstation: The workstation (in question) is running Win95C on a
> P-II 350 MHz machine with 64 Meg RAM. There is no virus
> software running on this workstation.
> Network: We are running a mixed NOS network, with a Novell 4.11
> server handling all of our file/print serving needs, and a NT4 server
> running Vantage. I'm using Novell's NDS4NT to assist in the user
> management for both the Novell tree and the NT domain. All
> workstations run both Novell's Client32 and Microsoft's client for
> Windows. We have a HP ProCurve Switch 4000M tieing it all
> together.
> For what it's worth, *My* workstation is a 350 MHz / 64 Meg RAM
> machine, also running Win95C (and I'm the MIS person!), and I
> *am* running a virus software, but my machine does not have this
> problem.
> Last night, I replaced the network card, updated the NIC drivers,
> hard set the card to full duplex, un-installed and re-installed
> Vantage's client. Same thing .... a several minute lag when going
> into something like Job Tracker.
> *** OH **** Just found out .... Our Data collection machines are
> doing this too !!!! Can't exactly tell people to *wait* 4-5 minutes
> when they want to log into a job, now can I ?!?!?!
> Signed,
> Praying for a Rolling Blackout in California
> Malcolm Spann
> MIS
> Malmberg Engineering
> (925) 606-6500 x19
> (925) 606-6505 FAX
> Malcolm@...
>snip<
the server.
together.
problem.
Signed,
Malcolm Spann
MIS
(925) 606-6500 x19
(925) 606-6505 FAX
Malcolm@...
Malcolm:
Rick
> the server.
> together.
> problem.
> Signed,
> Malcolm Spann
> MIS
> (925) 606-6500 x19
> (925) 606-6505 FAX
> Malcolm@...
> To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Having Novell connected to the network can slow things down.
You may want to temporarily uninstall the novel client on that machine and
see if it helps. I saw some articles in passing on microsoft's knowledge
base about novel/NT performance issues. You may want to explore that
avenue.
Of course the fact that other computers with the novell client run fine
suggests a slim possibility that this is the problem.
Might be worth checking, though.
Does anyone else have a similarly configured Novell/NT network that
works/doesn't work well?
Signed,
Praying for a rolling blackout in CA, except for the fact that the owners
just bought us some nice generators.
Sent: Thursday, May 10, 2001 10:35 AM
Subject: [Vantage] [Tech] Half/Full Duplex - followup
the server.
together.
problem.
Signed,
Malcolm Spann
MIS
(925) 606-6500 x19
(925) 606-6505 FAX
Malcolm@...
There is a Winsock version 2 upgrade at Microsoft that Epicor says should help Win95 workstations speed up. You can find the link on Epicor's home page.
Troy Funte
Liberty Electronics
Sent: Thursday, May 10, 2001 11:34 AM
the server.
together.
problem.
Signed,
Malcolm Spann
MIS
(925) 606-6500 x19
(925) 606-6505 FAX
Malcolm@...
Yahoo! Groups Sponsor
