Where would I find that?
On the Part record under Warehouses.
Maybe I am looking at the Time-Phase/Projected Balance incorrectly but here is what I’m seeing. The inventory is consumed and on 2/4 the balance is 103 with a demand on 2/10 of 6 which will reduce the on-hand below 100. My take is that the Suggestion tells you, you need to place an order (100 pieces) to arrive on 2/10 so that you don’t fall below the minimum.
If your MRP runs are being logged, the log files provide more detailed information on why that suggestion is being generated. Entering a file name in the Log field the MRP options will generate the log files on the app server.
Right but his minimum is 10 not 100
It looks like the logging is set to overwrite so I’m not sure where I’d find our MRP Logs.
The exact path varies by the company and user, but it should be something like this:
c:\EpicorData\Companies\<<Company>>\Log\<<UserID>>
My mistake, I filed Min Order Qty of 100 in head as Min Qty.
I’m not the system administrator so I’m not sure I’d have access to this / don’t know where I’d enter this path.
Sounds like unless I can get a hold of these logs I’m SOL?
Can you check the dates being used in your setup? If it’s on a schedule, see what the parameters are for that schedule. I’ve seen some weird issues where you have things like cutoff dates in the past, and/or historical dates allowed for jobs.
It looks like we have allow historical dates checked. Is that what’s causing these erratic suggestions?
It’s possible if you have old jobs mucking things up. I can’t say for sure that’s what’s going on, but I know that if your dates aren’t real (Aka, in the past and you aren’t done with it yet), it can be super confusing.
The path I posted would be on the Kinetic application server.
Probably? I’m not 100% sure.
Out of curiosity, on the top of that part in time phase, what does it say up here?
See above.
What I found for the part in the server logs is as is below. It looks like it’s considering jobs / consumption from April '24 that doesn’t show up in time phase. Is this because of the Lead Time CutOff?
13:44:06 Start Processing Part:C5269, Attribute Set:‘’, LLC:7-0
13:44:06 Processing Part:C5269, Attribute Set:‘’, Site:MfgSys, Contract:
13:44:06 Parameters: Receive Time → 0; Planning Fence → 30; Delta In → 30; Delta Out → 30; Lead Time CutOff → 3/6/2024 12:00:00 AM, Use Dynamic DOS → False, Allow Consume Min → True
13:44:06 Deleting Suggestions
13:44:06 Processing non-stock transactions for Part:C5269, Attribute Set:‘’
13:44:06 Processing stock transactions for Part:C5269, Attribute Set:‘’
13:44:06 Beginning Balance:166.00000000
13:44:06 Date changed, Process Date:
13:44:06 Date changed, Process Date:4/12/2024 12:00:00 AM
13:44:06 Over re-order, DoSuggestion…
13:44:06 After DoSuggestions, Balance:85.00000000
13:44:06 Date changed, Process Date:4/22/2024 12:00:00 AM
13:44:06 After DoSuggestions, Balance:84.00000000
13:44:06 Date changed, Process Date:4/23/2024 12:00:00 AM
13:44:06 After DoSuggestions, Balance:83.00000000
13:44:06 Date changed, Process Date:4/29/2024 12:00:00 AM
13:44:06 After DoSuggestions, Balance:82.00000000
13:44:06 Date changed, Process Date:4/30/2024 12:00:00 AM
13:44:06 After DoSuggestions, Balance:81.00000000
13:44:06 Date changed, Process Date:5/27/2024 12:00:00 AM
13:44:06 After DoSuggestions, Balance:77.00000000
13:44:06 Date changed, Process Date:6/3/2024 12:00:00 AM
13:44:06 After DoSuggestions, Balance:76.00000000
13:44:06 Date changed, Process Date:6/17/2024 12:00:00 AM
13:44:06 After DoSuggestions, Balance:75.00000000
13:44:06 Date changed, Process Date:7/1/2024 12:00:00 AM
13:44:06 After DoSuggestions, Balance:74.00000000
13:44:06 Date changed, Process Date:1/20/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:54.00000000
13:44:06 Date changed, Process Date:1/24/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:45.00000000
13:44:06 Date changed, Process Date:1/27/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:44.00000000
13:44:06 Date changed, Process Date:1/28/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:43.00000000
13:44:06 Date changed, Process Date:1/31/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:32.00000000
13:44:06 Date changed, Process Date:2/4/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:19.00000000
13:44:06 Date changed, Process Date:2/10/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:13.00000000
13:44:06 Date changed, Process Date:2/11/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:12.00000000
13:44:06 Date changed, Process Date:2/17/2025 12:00:00 AM
13:44:06 Below re-order, Expedite POs:2/17/2025 12:00:00 AM
13:44:06 Creating new PO suggestion for Part:C5269, Attribute Set:‘’, Date:2/17/2025 12:00:00 AM, Quantity:100.00000000 Number:5867895
13:44:06 Done with New Suggestion transaction
13:44:06 Date changed, Process Date:2/18/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:106.00000000
13:44:06 Date changed, Process Date:3/3/2025 12:00:00 AM
13:44:06 After DoSuggestions, Balance:105.00000000
13:44:06 Done with Part:C5269, Attribute Set:‘’
13:44:06 Finished Processing Part:C5269
See below. The Lead Time CutOff is set to 3/6/24. Is that what would drive these bum suggestions?
Have you done the math out to see if it brings you below the 10 qty?
