Install problem 9.04
Nor do I on a production box, but this is a test environment and I'm trying to make it as simple as possible.
So much for simplicity. Oh well.
Ernie
--- In vantage@yahoogroups.com, Ned <TechnoBabbly@...> wrote:
> Interesting, I wouldn't have thought of that because I never install
> anything Epicor related to the C drive, let alone the Program Files or
> Program Files (x86) folders.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Elizabeth
> Sent: Friday, July 20, 2012 4:27 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Install problem 9.04
> Thanks for getting back Ned, but the real problem is the OE install routine.
> I called support (since the basic uninstall/reinstall didn't work), and he
> sent me this:
> Summary: OE - "Can not find registry entry for Progress Open Edge"
> when installing server
> Book: Support Solutions
> Page: 12816MPS
> PAGE: 12816MPS
> PROBLEM DESCRIPTION:
> When trying to install the Epicor server software (32bit version of Epicor
> on a 64bit Windows OS), I receive the following error message:
> Can not find registry entry for Progress Open Edge (10.1c) Install Aborting.
> PROBLEM RESOLUTION:
> The OpenEdge software was installed in the Program Files directory instead
> of the Program Files (x86) directory and the Epicor server software install
> couldn't locate it.
> Uninstall OpenEdge 10.1c from the Windows Control Panel and reinstall
> OpenEdge into a non Program Files path (ex c:\epicor\oe101c).
> VERSIONS:
> 8.03
> 9.04
> 9.05
> --- In vantage@yahoogroups.com, Ned <TechnoBabbly@> wrote:
> > The install for 10.1C may not have gone well, it just happens from
> > time to time, I would uninstall it, restart, then re-install 10.1C and
> > then restart and try to install 9.04.
> > Behalf Of Elizabeth
> > Sent: Friday, July 20, 2012 8:58 AM
> > Subject: [Vantage] Install problem 9.04
> > Trying to create a test environment to upgrade from 9.04.507A to
> 9.05.700B.
> > Got myself a server with Server 2008 and SQL 2008R2, installed OE
> > 10.1C with service pack and hotfix, now trying to install 9.04 but I
> > get an error message "Can not find registry entry for Open Edge
> > (10.1C). Install aborting."
> > Am I supposed to install SQL 2005 to get 9.04 installed, then patch
> > 9.04 up to the 507A, then upgrade SQL to 2008, and THEN start upgrading to
> 9.05?
> > Confused,
> > Ernie Lowell
> > Diba Industries
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
Trying to create a test environment to upgrade from 9.04.507A to 9.05.700B. Got myself a server with Server 2008 and SQL 2008R2, installed OE 10.1C with service pack and hotfix, now trying to install 9.04 but I get an error message "Can not find registry entry for Open Edge (10.1C). Install aborting."
Am I supposed to install SQL 2005 to get 9.04 installed, then patch 9.04 up to the 507A, then upgrade SQL to 2008, and THEN start upgrading to 9.05?
Confused,
Ernie Lowell
Diba Industries
The install for 10.1C may not have gone well, it just happens from time to
time, I would uninstall it, restart, then re-install 10.1C and then restart
Elizabeth
aborting."
Confused,
Ernie Lowell
Diba Industries
I called support (since the basic uninstall/reinstall didn't work), and he sent me this:
Summary: OE - "Can not find registry entry for Progress Open Edge" when installing server
Page: 12816MPS
PAGE: 12816MPS
When trying to install the Epicor server software (32bit version of Epicor on a 64bit Windows OS), I receive the following error message:
Install Aborting.
PROBLEM RESOLUTION:
The OpenEdge software was installed in the Program Files directory instead of the Program Files (x86) directory and the Epicor server software install couldn't locate it.
Uninstall OpenEdge 10.1c from the Windows Control Panel and reinstall OpenEdge into a non Program Files path (ex c:\epicor\oe101c).
VERSIONS:
8.03
9.04
9.05
> Elizabeth
> aborting."
> Confused,
> Ernie Lowell
> Diba Industries
Elizabeth
sent me this:
Page: 12816MPS
PAGE: 12816MPS
PROBLEM RESOLUTION:
couldn't locate it.
VERSIONS:
8.03
9.04
9.05
> Behalf Of Elizabeth
9.05.700B.
9.05?
> Confused,
> Ernie Lowell
> Diba Industries
