It's here.... 2026.1.100 Feedback Thread (Behave 🤣 )
What is EDI HQ? Is that the same as OneEDI/ Epicor EDI?
Does this product still output a file that demand management has to pick up through the import EDI process?
Chris Farley Idk GIF
I forgot, didn’t you write your own EDI program? Or inherit it? I forget haha, I know we talked about this at insights…
Schitts Creek No GIF by CBC
But I kinda wish I had.
I did have to write the piping to make some of it work between a vendor and our solution.
Yes…
EDIT - sorry for the short answer earlier…was getting our EDIHQ instance refired and running again. Inbound orders use the Demand Management ā€œImport EDI Processā€. Everything else is largely BPM/function-driven at the document level, leveraging Azure filepaths and/or report styles.
Anyone seen this popup when logging in?
Holding down shift to multi-select on a grid is finally working . . . not sure its working everywhere but in a lot of places.
Are you able to get in? You can look at your BPM’s. Are any of them ā€œOutdatedā€?
If there are you can run the Update - Recompile to bring them back online. This worked for me, though, I wasn’t seeing the same error during log-in.
Just something you can check/try.
Yes I get in no problem. Only our test environments are upgraded to 26.100 at the moment, live will probably be in July
Devil’s Advocate.
The others go from smallest/largest fragment of time to the opposite, but the same could be said for the American format which is organized by range size. Month numbers go from 1-12 which is a smaller range than days which goes from 1-31 and the finally years which are infinitely big, or at least until the sun goes out. :woman_shrugging:t2:
That’s my useless contribution for the day. I’ma go back into my hidey hole.
At least we know you’re somewhere haha, haven’t heard from you in what feels like forever!
Yes, I’ve had to update 51 BPMs thus far to be compatible with Entity Framework Core as it’s more strict than EF6. There is a thread on in here
where has the Dashboard Menu / Dashboard Maintenance gone to? I can’t find it anywhere
That no longer exists.
how do i deploy a dashboard now?
That has only ever showed Classic dashboards - and therefore is no longer in 2026.100.
You need Application Studio. Apps of type dashboard will start with Ice.UIDbd. in their Application ID.
okay so I was having a BAQ dashboard, and I just made the BAQ to be updateable so I wanted to redeploy the dashboard. Does that mean i will need to figure those out inside application studio alone, using editable and some events-functions?
Application Studio does have guided setup wizards on the dataview to be able to control updateability, which fields, etc.
