klincecum
(Kevin Lincecum)
4
Unfortunately, you can’t do that
They both map to Erp.Tablesets.JobProdRow
You can try switching to use var
, which may work if the types are identical.
Edit: Depending on what you’re doing, you could also use dynamic
Or you can load the type via reflection.
You can also break it into two functions, however they will have to be in separate libraries
