I see that Kinetic 2022.2 is available for download today and was going to install on our development server. My dev server is currently on 2022.1.10. Do I have to download and install RL11.2.200 first and then the UD11.2.200.4? Or do i only download and install the UD11.2.200.4?
In the same download section there’s a PDF that has step by step instructions on upgrading. I would download and follow that.
I second the documentation,. Typically you install the full new release, and uncheck the open Admin console checkbox, then do the install for the update, and keep the open Admin console checkbox checked and add in a new app server.
Please don’t be confused either, screenshots for the current install document for 2022.2 show 2022_1 as examples, so adjust your aim.
I am sure at some point an update to the install document will hit the downloads.
Links are:
For a full fresh install use this guide: https://epicweb.epicor.com/dwn/DownloadFile.aspx?url=8A36ABB36983CB637AEB5A6C67DB90A388A79D22
For UPGRADING an existing instance from 10.0, 10.1 or 10.2: https://epicweb.epicor.com/dwn/DownloadFile.aspx?url=2BD42D00142F08A7EF9048801E983E317AD79BFE
For Migrating from 9.05 to 2022.2: https://epicweb.epicor.com/dwn/DownloadFile.aspx?url=BF5F949E9C7859D8258A5B0FD93F88BEF0084969
For the 2022.2.4 Update which as mentioned you would apply after the initial install: https://epicweb.epicor.com/dwn/DownloadFile.aspx?url=2D313607BB9FBB4E79266A761B0D4DBA127F7870
You will need an Epicweb username and password, and an up to date paid maintenance to be able to download.
I do strongly encourage everyone who hasn’t, to peruse the documentation section, not only for the current version, but earlier releases for some of those gems that will help you on your journey, like the BPM cookbook. Here is the link Sign In.
