When you set it up make sure you have a user with a mailbox. Or you’ll run into issues. You can use shared mailboxes with send as delegate permissions. Thread linked below from recently with some good information.
I appreciate you sharing the topic. Our current legacy Epicor ERP Manage 2000 uses an Epicor provided relay service called VSI-FAX. Gotta say the SMTP relay sounds like the best idea then maintaining 365. We have zero issues currently with VSI-FAX.
I’ve used Azure Communication Services. It works like any bulk SMTP. It’s just not free. If you’re already paying for M365 you might as well use the M365 SMTP if you don’t have another SMTP relay service.
Whoa…they’re still around? We used them way back in the day…tied to our old iSeries-based ERP, ran on a PC side by side with Adobe Central Output Server.
I know @aidacra wrote up a good KB Article on it… I can’t find it. Not sure if its up-to-date for 2026.
aidacra
(Epicor Employee: Nathan your friendly neighborhood Support Engineer)
13
KB0108152 Using Microsoft 365 (formerly Office 365) for Outbound Email using SMTP
There are a couple of blurbs that refer to the Entering Microsoft 365Settings topic within the Entering Mail Settings Kinetic application help article for creating an app registration instead of using SMTP.
As an aside, Cloud customers who prefer not to manage outbound email configuration in Kinetic can request that Epicor configure their environments to send email through our SendGrid subscription instead. There is no additional fee for that.
Free SendGrid sounds amazing. Our Epicor provided VSI-FAX has zero issues. This would be a comparable solution.
Do you have the details such as pros and cons of this decision?
Thank you!
aidacra
15
Pros: Using Epicor’s managed SendGrid service eliminates the need to configure, monitor, and maintain outbound email infrastructure for your Cloud environments.
Cons: Customers do not have direct access to delivery or message-level troubleshooting details. This includes limited visibility into recipient-side email delivery issues such as bounces, blocks, spam filtering, suppression lists, or invalid email addresses.
Is there a third option like bring your own SendGrid (or Azure Communication Services, Mailgun, Postmark, Amazon SES) and remove the complexity of email by using Web Requests/REST/Webhooks instead of SMTP, M365, or Google Workspace?
aidacra
17
How do you get the different apps to send from different shared mailboxes? In the Email settings I see a chackbox for "Use Individual’s email From field and I understand the idea of send as permissions in M365, but where does this “From” field come in?
Alternately how are you making the Shared mailboxes work? SO far I only see the emails coming from the account set up in the Email settings screen?!?!?
My purchasing team is coming from “Peachtree” or better known as Sage Quantum. A locally installed application that allows them to send emails using their personal Outlook instance where it creates a new email for them and they hit send in their Outlook. This team relies heavily on their “Sent Items” so they tell when they sent a PO.
They are not sending emails from Epicor (we are cloud SaaS) because the emails are not in their sent items so they can’t see that they actually sent the email or not, or maybe even what the PO looked like when they sent it out. Instead they use Print Preview to make a PDF then they manually have to create an email, attach the PDF.
