Kinetic Control Compendium
Selection List
Allows a user to select and sort a collection of data items.
This control has a few different flavors to it and can be changed up visually in a number of different ways.
Property Group Property Description
Basic Id Unique identifier for the control
Basic Label Text Sets the label within the control. (Fig. A)
Behavior On Blur Click this to create an OnBlur event for the control. On Blur is triggered when the control loses focus.
Behavior On Create Click this to create an OnCreate event for the control On Create is triggered when the control is painted to the GUI.
Comments Comments Add some developer notes to the control. These are not customer-facing and are only visible in App Studio (Fig. B)
Data Key Field Indicates that a bound component is a key field. If true, the field is enabled if there is no current record, allowing the user to select an existing record or create a new one. Not relevant to this control.
Data EpBinding Bind the control to a DataView.Column. This is used to store the delimited list of items. Can be used to apply row rules to the control.
Data List This can be used to define hard coded items for the list instead of a dataview.
Data > List Id Unique ID for the item. (Fig. C)
Data > List Text Set the text value for the item (Fig. C)
Data > List Id Name :mag_right: Obsolete
Data > List Description Set the detailed description for the item (Fig. C)
Data > List SubText :mag_right: Set the sub-text value for the item. Doesn’t seem to do anything.
Data > List LeftIcon :mag_right: Set the icon for the list item. Doesn’t seem to do anything.
Data > List Command :mag_right: Set the command string for the list item. No clue here.
Data > List Selected Set the flag to indicated if the item is selected by default. (Fig. C)
Data > List Checkmark Hidden Set the flag to indicate if the selected item has a hidden checkmark. Seems weird, but okay. (Fig. C)
Data > List Toggle Disabled Set the flag to indicate if the item is disabled. This works, as in you cannot select it, but there’s no visual indicator to indicate that. (Fig. C)
Data > List Required Set the flag to require this list item. (Fig. C)
Data > List Bookmark :mag_right: Set the flag indicating the list item has a bookmark. #Shrug
Dataviews Source View Name Set the view name used to populated the source list. Format: DataView
Dataviews Source Table Name :mag_right: Set the table name used to populate the source list. Unsure on this one. It’s not clear what a table is within the context of App Studio.
Dataviews Source Code Col Column name used to populate the source list item ID. Format: ColumnName
Dataviews Source Desc Col Column name used to populate the source list item description. Format: ColumnName
Dataviews Target View Name Set the view name used to populated the targetlist. Format: DataView
Dataviews Target Table Name :mag_right: Set the table name used to populate the target list. Unsure on this one. It’s not clear what a table is within the context of App Studio.
Dataviews Target Code Col Column name used to populate the target list item ID. Format: ColumnName
Dataviews Target Desc Col :mag_right: Column name used to populate the target list item description. It yells at you in Dev Tools if you populate this. Format: ColumnName
Dataviews Table Name Set the table name used with source AND target codes and descriptions
Dataviews Parent Related Col Set the name of the column on the parent table. Used when binding to parent/child related tables.
Dataviews Child Related Col Set the name of the column on the child table. Used when binding to parent/child related tables.
Dataviews Related Col Set the shared name of the column on both the parent and child tables. Used when binding to parent/child related tables.
Layout Alignment Sets the alignment of the control. (Fig. D)
Layout Width Sets the specific width (pixels) for the control. (Fig. E)
State Personalizable If true, a user can personalize this component(hide/show)
State Customizable If true, a user can customize this component in child layers
State Hidden Hides the control from view.
State Disabled Disables the control. The control will not allow editing or focus.
State Read Only Makes the control read only so that it will not allow editing. The control can still be focused.
State Auto Focus When enabled, the control is automatically focused on creation.
Advanced Target Label Text Set the label text for the target list. (Fig. F)
Advanced Mode Type Set the display mode. Valid options include: Single and Dual. (Fig. G)
Advanced UI Mode Set the selection mode. Valid options include: Select, Switch, :mag_right: SingleSelect (Doesn’t really stop you), Checkbox. (Fig. H)
Advanced Position Mode Set the position of the text. Valid Options Include: Left or Right (Fig. I)
Advanced Reorder Set the reorder mode. Valid Options Include: Select or All (Fig. J)
Advanced Header :mag_right: Sets the label text for the list. Only used on Panel Mode. Not sure what panel mode is, but it ain’t this!
Advanced Limit :mag_right: Sets the limit of the items to be displayed. Only used on Panel Mode. Not sure what panel mode is, but it ain’t this!
Advanced Rows Sets the number of items to be displayed (can scroll for more). Used in all modes except Panel. (Fig. K)
Advanced Manual Sort :mag_right: Sets the flag indicating if a sort button should be shown. Doesn’t do anything. Might be only for “Panel Mode”
Advanced Show Edit :mag_right: Set the flag indicating if an edit button should be shown. Only for Panel Mode. WTF IS PANEL MODE??
Advanced Enable Edit :mag_right: Set the flag indicating if editing of list items is allowed. Only used on… you guess it… Panel Mode.
Advanced Enable Header Edit :mag_right: Sets the flag indicating if the edit button should be presented at the top of the list. OnLy UsEd In PaNeL mOdE.
Advanced Value Primitive :mag_right: Specify the type of the selected value. If set to true, the selected value has to be of a primitive value.
Advanced Delimited Set the flag indicating if the multi-select value for binding is delimited. This is required for multi select.
Advanced Delimiter Set the delimiter character. Valid options include: ~ , ` (tilde, comma, tick).
Advanced EpiLabel :mag_right: Obsolete
Advanced Draggable :mag_right: Obsolete
Figure A: Label Text
Figure B: Comments
Figure C: Items
Figure D: Alignment
Figure E: Width
Figure F: Target Label Text
Figure G: Mode Type
Figure H: UI Mode
Figure I: Position Mode
Figure J: Reorder
Figure K : Rows
More info on setup from an older post: How To: Kinetic Selectable List
