Kinetic Dashboard Development
Hi everyone,
I’m in the process of creating/uplifting a classic WinForms dashboard to Kinetic Application Studio and I’m trying to replicate a fairly involved button click workflow.
On button click, the logic does the following:
  1. Reads selected rows from a grid (Pack Slips)
  2. Builds a *-delimited string of ShipHead.PackNum
  3. Calls a Published Epicor Function via REST:
  • Library: MasterPackAutomation
  • Function: ProcessPackSlips
  • Input: packIds (string)
  1. The function returns two outputs:
  • masterPacks (string)
  • packErrors (string)
  1. Based on the response:
  • Show error message if packErrors has data
  • Show success message if masterPacks has data
This is currently working fine using Client.
Now, I want to implement the same behavior in Application Studio, specifically:
  • Collect selected grid rows
  • Loop through them to build a single input value
  • Call this Epicor Function
  • Capture return parameters
Where I’m stuck / need guidance
  • Best practice for looping selected rows and building an input parameter with ‘*’
  • Correct way to map multiple function return values in Application Studio
So far, I have button which is calling the function,currently, I am testing with only one value and based on that I also did the trace which return null.
If anyone has a working pattern, screenshots, or example for this kind of flow, I’d really appreciate it.
Thanks in advance!
I’ve got a similar for a Dashboard that reads/writes to UD10. This is the Save flow that sends the row data to the function for processing, gets a response and depending on what’s returned the Condition will display the returned error message or refresh the grid.
If @Randy’s solution doesn’t quite work (though I have no doubts it will), this thread where him, @dcamlin, and I worked through something similar (in reverse of building the delimited list) might also provide some useful insights:
I have used both approach and had got me started. Big thanks to @Randy , @d_inman , @dcamlin !Thank you for your help!
I was able to build delimited and pass it to my function. I want to handle the response and show it under MessageBox. I tried using OnSuccess after function run to show {actionResult.masterPacks} and it shows up fine.
And same on OnError after function run to show {actionResult.packErrors}. Is this the correct approach?
