Sue
Sue
Hello-
When entering labor hours via the time and expense screen, we would like the burden hours to automatically populate with the number of hours we enter into the labor field. I was told the Labor=Burden glag set to ON in the resource group record would allow this but the burden field does not populate even though it is checked. s there a way to set this up without using a BPM?
Thanks for your response-
Lynn
This would normally happen when your guys clock into Epicor using MES. Every Labor hour will equal a Burden hour when you have Labor=Burden on the resource group.
But through Time and Expense Entry this will NOT happen. You have to add it manually. Or like you mentioned a BPM.
Manasa
Sent: Thursday, January 15, 2015 11:40 AM
Subject: [Vantage] Labor=Buden on Time and Expense screen
Hello-
Lynn
