I am working on a customization for end activity and I have to access the labordtl to see if the job I am working on is a active transaction so I can pass the amount completed for the operation. The issue that I am having is that the labordtl table is empty. It should have some rows in there for non active transactions, but those do not show up either. I think the problem may be that I am using a before adapter method so it might be clearing the table as this method happens. Is there a way to access the table when it has rows in it in the before adapter method.
LaborAdapter Labor = new LaborAdapter(EndActForm);
Labor.BOConnect();
DataSet laborset = Labor.GetData(empID);
EpiMessageBox.Show(laborset.Tables[“LaborDtl”].Rows.Count.ToString());
Here is the code for how I am accessing the table.
