RichK
(Richard Kettle)
1
I would like to know if there is a way to pull in a part’s description into the configurator UI while configuring a part.
So I could type in the part number into an input in the configurator, then that part description appears in a separate input.
Is this possible?
This is possible using a server UD method. Are you a SaaS customer?
utaylor
(Utah Taylor)
3
You can make the control bound to a dynamic query if that works for you.
RichK
(Richard Kettle)
4
Hi, as far as I know we are not a SaaS customer.
What function can I use in the UD method to do this?
