Looking for Job Operation Final Operation field
I am looking for the Job Operation FinalOperation field in the JobOper table and I do not see it.
Does anyone know what that field is called and/or how i can find it?
DaveO
Found it - JobAsmbl :frowning:
I was just having a look around for this field. I am working with DMT and you can import a field called PartOpr.FinalOp. As a Boolean field. But there is no boolean field to export, so you have to look at the PartRev.FinalOpeartion, which is an integer that points to the operation that has been identified as the final op for this rev. Kind of confusing, but it works.
