Maintenance processor: Where/how do I check if it is running?
We use the maintenance module, and I was told that the preventive maintenance jobs are not getting automatically generated. I read that there is a maintenance processor to be activated.
I am trying to find out where , when it is activated, this is run? If anyone can guide me as where to look…because so far I did not find it on the server. (hey… maybe the reason the jobs are not created ! :thinking:)
So if I run it now, I want to find out if it is activated… so where to look ?
Thanks.
Pierre
Does that dropdown for the schedule look like the list you see for report scheduling? If so, I’d expect it to show in the task agent / SysMon (when submitted to a recurring schedule)
Yes I have discovered it late…!
So it is setup to run every day at 4:15 am.
I did a test ( changing the date to today for one of the equipment plan ) and ran it manually (run NOW) and no job was created.
I do not know what is missing… This was working before, and it’s been awhile it does not work… (since our upgrade maybe? cannot tell… )
I have opened a ticket with Epicor…
Will update then…
Thank you.
Pierre
