Actually I said that we had labor rates set in the resource groups.
It looks as if our problem is just not entering labor rates in the
employee file.
Thank you.
employee file.
Thank you.
--- In vantage@yahoogroups.com, <sarah.vareschi@...> wrote:
> You can set it up however you want, depending on your business.
For us,
> we often have 1 person running multiple machines, or machines
running
> unattended, so we need to track burden rates & hours separately
from
> labor rates & hours. If you do not do that, the system does not
require
> it and yo can have just a labor rate (in employee master file) *
labor
> hours hitting the job.
> My point was, if you have a burden costing rate in the resource
group
> (which I thought you said previously that you did) and your jobs
get
> burden hours applied, you should be seeing those costs hit your
jobs if
> time is being applied properly.
> -----Original Message-----
Behalf
> Of rkbiggs
> Sent: Thursday, November 15, 2007 9:31 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Material Cost/Labor Cost Absent
> Are you saying the actual labor costs come from the rate in the
> employee file and the actual burden costs come form the rate in
the
> resource group? Burden hours are hitting correctly but the boss
> chose not to enter burden rates because he says he isn't tracking
> burden, just labor. Our burden hours equal labor hours.
> --- In vantage@yahoogroups.com, <sarah.vareschi@> wrote:
> > If you have rates in your resource groups, you should still see
> costs
> > hitting the jobs though.
> > We have 2 sets of rates, a labor rate in the employee file and a
> burden
> > rate in the resource group. When an employee logs off a job,
the
> total
> > labor hours * labor rate get applied as do the total burden
hours *
> > burden rate. Are burden hours hitting your jobs correctly?
On
> Behalf
> > Of rkbiggs
> > Sent: Wednesday, November 14, 2007 4:26 PM
> > We have the part cost issue resolved. That is working great now.
> It
> > appears the labor cost issue is due to not entering labor rates
> for
> > the employees. I'll work on that tomorrow and see if that solves
> our
> > problem.
> > Again, thank you to everyone that has helped.
> > We are very new to Vista and appreciate all the help we can get.
> > --- In vantage@yahoogroups.com, "Stan Chmura" <schmura@> wrote:
> > > Do the part costs for the parts issued to jobs show in part
> > tracker, and do
> > > they match the cost method? i.e. if you use Average cost
method
> > the cost
> > > will come from the Average cost field when issued to jobs.
That
> > field
> > > cannot be at 0. Likewise for Last and Standard Cost methods.
> > > _____
> On
> > Behalf Of
> > > Monte Tomerlin
> > > Sent: Wednesday, November 14, 2007 3:42 PM
> > > Labor Rates enter in Resource Group setup applies only to the
> > Estimated
> > > Labor Cost for the Job or in Quoting. It is the specific Labor
> > Rate of
> > > a specific employee which hits the Job. This Labor Rate is
enter
> > in
> > > Shop Employee under Job Management unless you have the Payroll
> > module
> > > and it is entered in Payroll setup for the employee. - Monte
> > Tomerlin
> > > --- In vantage@yahoogroups <mailto:vantage%
> 40yahoogroups.com> .com,
> > > "rkbiggs" <rkbiggs@> wrote:
> > > > Vista 8.03.305 - When reviewing jobs in Job Tracker or
Project
> > the
> > > > Actual Labor Cost and Actual Material Cost show as zero. The
> > jobs are
> > > > marked as closed. All material has been issued to the jobs.
> Has
> > > anyone
> > > > else encountered this? Maybe we are missing a step in the
> > process? We
> > > > had the understanding that as transactions were made against
a
> > job
> > > > that the cost would update. Is this wrong?
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> must
> > have already linked your email address to a yahoo id to enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Yahoo! Groups Links
> > <DIV><font size="1.5" face="Bookman Old
Style">______________________________________________________________
> > This email may contain material that is confidential, privileged
> and/or attorney work product for the sole use of the intended
> recipient. Any review, reliance or distribution by others or
> forwarding without express permission is strictly prohibited. If
you
> are not the intended recipient, please contact the sender and
delete
> all copies.
_____________________________________________________________________
> _____________________________________________<DIV><FONT>
must
access. )
Builder
> Yahoo! Groups Links
forwarding without express permission is strictly prohibited. If you
are not the intended recipient, please contact the sender and delete
all copies.
