We are trying to get everyone using an Epicor handheld to process physical moves by scanning the Material Queue Sequence ID (MtlQueue.MtlQueueSeq).
The problem is that if an Operation has “Request Move” checked but the operation itself is split up into multiple labors, it dumps the move requests to the queue onto the same row. It does a RowMod update and stacks it into a pool. It then sits there to Process, at which time it is physically deleted from that table. Subsequent Move Requests on the same operation after this are assigned a new MtlQueueSeq. This is troublesome and terrible.
I need every Labor End Activity that occurs with a Request Move to put these on a new row with its own unique MtlQueueSeq.
The reasoning for this is because, for example, if they split up an operation of 30 parts across 3 machines, you end up with 3 palettes of 10 parts, but the queue only shows a single row of 30. If someone goes to move these, they might grab the first set of 10 and leave behind the other two because the label that I have triggering off this action only has a single mtlqueueseq barcode for the lot of them.
But not always, cause if a process move occurs in the middle, you could end up with 2 with one seqId, and 1 with a different one for the same Opr. Urgh!
I’m open to any and all solutions.
My thought was to do an In-Transaction BPM to convert “Update” rowmods into “Add”, and somehow assign a unique ID, but this results in manipulating the temp table before Update and generating multiple dirty rows. I now there are caveats to this, but I don’t know what they are.
In addition, I don’t want to manually create the Id (since the rows are gone, I can’t anyway) but since Epicor remembers somehow the last value used even if the physical row is gone, I’m hoping there is an auto-assign I can slap into c# code and do this. I need to ensure MtlQueueSeq is unique on every label I print.
I can manipulate the json I’m sending to Bartender later for Quantities and Totals. I’m not concerned about that yet.
