I need to populate the callContextBpmData.ShortChar01 with the RcvHead.PackSlip number in the Receipt Entry screen.
I have attempted this by first creating a customization in the Receipt Entry (parent) screen and then creating a customization in the Material Tags (child) screen. I then used Process Calling Maintenance to setup the Called Process (Erp.UIRpt.MtlTags), the Called From (Erp.UI.ReceiptEntry) and the menu ID that I created (which points to the customization in the MtlTags Form) under âProcessesâ in Menu Maintenance.
In the customization for the Receipt Entry screen, I have the following code:
I am sure that I do not have the correct Form Event. I am also not sure when one chooses the Action Menu / Print Tags which Form Event fires.
In the Material Labels dialog I created a customization that includes a text control and have set the epibinding to CallContextBpmData.ShortChar01. I am not quite sure how I go about populating that EpiBound field with the LaunchFormOptions object.
This is my first attempt at writing a customization of this nature and am not sure if I am using the correct approach to what I am trying to accomplish. Any assistance is most appreciated.
You are passing a TextBox object instead of the text of that TextBox.
Try getting the .Text property.
Or, get the data from the EpiDaraView (better choice). You can also look in Object Explorer and youâd find oTrans.PackSlip gives the simpler version.
James, youâre on the right track. A few tips though:
You should use the BeforeToolClick event and handle it so it overrides the default MtlTags form call
Use the LaunchFormOptions.ValueIn property to pass the parameters normally passed to the base MtlTags form and use LaunchFormOptions.ContextValue to pass the packslip
In your MtlTags customization, use the form load to extract your packslip from the ContextValue and set the packslip value in the appropriate dataview
If you give me some time to look up my code, I can give you a detailed walkthrough because I did the exact same thing that youâre trying to do right now.
Thank you Tanesh. The info will help me progress. Canât thank you enough. I would love to see the code, but donât rush. Post when it is convenient for you!
In your Receipt Entry customization, add a BeforeToolClick event handler. Populate it with the code below. ShowCustomMtlTags() is where the real magic will happen.
In ShowCustomMtlTags(), create the LaunchFormOptions object. ValueIn is how Epicor passes the material tag parameters to the report, so weâll do the same. ContextValue is what weâll use for our custom data.
That takes care of the Receipt Entry customization. Now in the Material Tags customization, use the form load event to to extract the packslip and set callContextBpmData.ShortChar01âs value
This is excellent information. This will certainly help in many ways as I learn by example. A thousand thanks for your time and efforts Tanesh. Most appreciated.
Tanesh, I am apparently having a problem with the correct placement of the semicolon ; in the BuildMtlTagParams(). I cannot seem to find where I am missing one. Everything appears in place, but apparently isnât. Do you see anything that is obvious by chance?
Probably the < in the if condition. This is what happens when I copy code straight from the XML smh.
Replace it with â<â and you should be good to go.
Thank you Tanesh, that allowed me to complete the customization for the Receipt Entry screen successfully.
Moving on to the Print Material Tags screen, Iâve added the script but am getting a compile error. It references either a directive or assembly reference, but I looked in Assembly Reference Manager and could find nothing related to that function.
Compiling Custom Code âŚ
----------errors and warnings------------
Error: CS1061 - line 57 (152) - âScriptâ does not contain a definition for âcallContextBpmDataViewâ and no extension method âcallContextBpmDataViewâ accepting a first argument of type âScriptâ could be found (are you missing a using directive or an assembly reference?)
I have added the row per your last response, but am still receiving a compile error when testing the code. Even after researching for examples of code to try to sort it out myself, this is really making me feel like a neophyte; but I still persevere! I have copied the entire code from the Print Material Tags script and pasted below. The compile error message follows the code:
// Custom code for MtlTagsForm
// Created: 11/11/2019 1:15:39 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
// Begin Custom Code Disposal
// End Custom Code Disposal
private void MtlTagsForm_Load(object sender, EventArgs args)
// Add Event Handler Code
callContextBpmDataView = (EpiDataView) this.oTrans.EpiDataViews[(object) "CallContextBpmData"];
if (this.MtlTagsForm.LaunchFormOptions != null)
this.callContextBpmDataView.dataView[this.callContextBpmDataView.Row]["ShortChar01"] = this.MtlTagsForm.LaunchFormOptions.ContextValue.ToString();
Error: CS0103 - line 57 (191) - The name âcallContextBpmDataViewâ does not exist in the current context
Error: CS1061 - line 60 (194) - âScriptâ does not contain a definition for âcallContextBpmDataViewâ and no extension method âcallContextBpmDataViewâ accepting a first argument of type âScriptâ could be found (are you missing a using directive or an assembly reference?)
Finally, Iâve managed to test the code without error. So, both the script in the Receipt Entry and the Print Material Tags dialog are compiling successfully. Now when I bring up a receipt in then Receipt Entry, choose a packing slip and then select Print Tags from the Actions menu, I receive the following error:
Application Error
Exception caught in: Erp.UIRpt.MtlTags
Error Detail
Message: Index was outside the bounds of the array.
Program: Erp.UIRpt.MtlTags.dll
Method: setIncomingParamsFromReceiptEntry
Client Stack Trace
at Erp.UI.Rpt.MtlTags.Transaction.setIncomingParamsFromReceiptEntry(String[] parameters)
at Erp.UI.Rpt.MtlTags.MtlTagsForm.OnFormLoaded()
at Ice.Lib.Framework.EpiBaseForm.formLoaded()
My best guess - it doesnât like something about the ~ delimited parameters youâre sending over. If you have Visual Studio, you can debug your Receipt Entry customization to see exactly whatâs being returned by BuildMtlTagParams()
Tanesh, I believe that in the original code you gave me at the top of this thread, there is a duplicate of âOurQtyâ in the BuildMtlTagParams(). Should one of them be removed?
I did remove one and ran the customization, now when I launch the Print Material Tags dialog, I am receiving the following different error instead of the âIndex was outside the bounds of the arrayâ error:
Application Error
Exception caught in: mscorlib
Error Detail
Message: Input string was not in a correct format.
Program: CommonLanguageRuntimeLibrary
Method: StringToNumber
Client Stack Trace
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseDecimal(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Convert.ToDecimal(String value)
This is my code for the Receipt Entry screen:
// Custom code for ReceiptEntryForm
// Created: 11/5/2019 8:40:35 AM
extern alias Erp_Contracts_BO_Receipt;
extern alias Erp_Contracts_BO_ICReceiptSearch;
extern alias Erp_Contracts_BO_SupplierXRef;
extern alias Erp_Contracts_BO_Currency;
extern alias Erp_Contracts_BO_Company;
extern alias Erp_Contracts_BO_Part;
extern alias Erp_Contracts_BO_Vendor;
extern alias Erp_Contracts_BO_VendorPPSearch;
extern alias Erp_Contracts_BO_JobEntry;
extern alias Erp_Contracts_BO_JobAsmSearch;
using System;
using System.Data;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
public class Script
this.ReceiptEntryForm.BeforeToolClick += new Ice.Lib.Framework.BeforeToolClickEventHandler(this.ReceiptEntryForm_BeforeToolClick);
this.ReceiptEntryForm.BeforeToolClick -= new Ice.Lib.Framework.BeforeToolClickEventHandler(this.ReceiptEntryForm_BeforeToolClick);
private void ReceiptEntryForm_BeforeToolClick(object sender, Ice.Lib.Framework.BeforeToolClickEventArgs args)
switch (args.Tool.Key)
case "PrintTagsTool":
args.Handled = true;
ShowCustomMtlTags();
break;
private void ShowCustomMtlTags()
LaunchFormOptions opts = new LaunchFormOptions();
opts.IsModal = false;
opts.ValueIn = BuildMtlTagParams();
opts.ContextValue = "txtKeyField";
ProcessCaller.LaunchForm(oTrans, "UDMT01", opts);
private string BuildMtlTagParams()
string str = "~";
System.Text.StringBuilder stringBuilder = new System.Text.StringBuilder(string.Empty);
EpiDataView epiDataView = (EpiDataView) null;
EpiDataView rcvDtlView = ((EpiDataView)(this.oTrans.EpiDataViews["ReceiptRcvDtl"]));
if (rcvDtlView.Row < 0)
else;
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["PartNum"].ToString());
stringBuilder.Append(str);
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["PartDescription"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["OurQty"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["ReceivedTo"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["RevisionNum"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["JobNum"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["PONum"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["POLine"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["PORelNum"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["VendorNum"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["ReasonCode"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["WareHouseCode"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["BinNum"].ToString());
stringBuilder.Append(rcvDtlView.dataView[rcvDtlView.Row]["LotNum"].ToString());
return stringBuilder.ToString();
The base Receipt Entry form specifies the âOurQtyâ parameter twice, so I do the same.
Iâm on 10.1.600.9, so if youâre on a different version, it may expect different parameters or expect them in a different order. The best way to figure this out is to look at the parameters being sent and verify that itâs what the Material Tags form expects
