Menu registration
Hello, everyone.
I registered the Dashboard I made to the Menu through Menu Maintenance.
But after that, whenever I log in to Epicor, that menu opens automatically.
Did I do something wrong when registering the menu?
Please advise.
I am not sure why that happened from menu maintenance, but if you go to Settings > Prefs > Tabs you can see anything set to autoload.
Like @NateS said, it’s probably not Menu Maintenance. There is an option when you Deploy the Dashboard to add it to a tab and that was probably checked.
You’re right. I clicked Add Menu Tab when deploying. Before that, I didn’t do that.
Thanks for your great advice.
thank you. As you said I went into settings and deleted that menu. So I solved it.
Thanks for your advice that’s just right for me.
