MES User Login Protocol
The generic 'shop' username is simply a (Vantage CAM) recommended device to allow our 30Â MES users to share access to MES efficiently on about 10 winterminals deployed throughout the shop.
Â
Actual activity is reported by these users using their individual clock IDs (which, to keep things simple, are the same as their non-Vantage payroll employee IDs).
Â
No problems attributable to this so far other than coaching/instilling the self discipline to clock out at the end of each day (rather than logging out - which doesn't perform a simultaneous clock out).
Â
Rob Brown
--- On Tue, 7/1/08, Michael McWilliams <mmcwilliams22@...> wrote:
Subject: [Vantage] Re: MES User Login Protocol
Date: Tuesday, July 1, 2008, 2:35 PM
Have you noticed any issues using the same username for all MES
users. We had a problem a while back that Epicor did not have a
specific answer for. They attributed it to using the same login for
all MES users. We changed them, and don't have the issues anymore.
I can't say for sure that was the cause though.
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
wrote:
> Have a cold one for me Nick. I'll enjoy it through osmosis :)
> Rob
> --- On Tue, 7/1/08, nmtaylor1969 <n.taylor@.. .> wrote:
> From: nmtaylor1969 <n.taylor@.. .>
> To: vantage@yahoogroups .com
> Date: Tuesday, July 1, 2008, 12:08 PM
> Wise words as always Rob, thanks... You should write a book!! ;o)
> We are currently using an external time management system that is
not
> part of Vantage, and I am the first to admit that we have some
real
> discipline issues to sort out in terms of operators recording
> accurately what they do. Funnily enough they are always very good
at
> recording their physical hours on site for the purposes of
payroll,
> but not so good at recording what they do when they are on
site ;o) A
> big part of our implementation is the cultural change that must
take
> place in order to run an effective MRP system. Rubbish in, rubbish
> out and all that...
> We closed our first jobs off today and that was not a pleasant
> experience. Problems caused by lack of procedure around the
creation
> of parts has come back to haunt us. We will do better next time I
am
> sure. At least being in the UK I can now go for a cold beer whilst
> you guys in the US keep working hard. Enjoy!
> Thanks,
> Nick
> wrote:
> > Initially login to MES using the generic username 'shop'
> (psswrd 'shop').
> > That will allow your shop employees to enter their ID numbers in
> IF their associated usernames have a password, they will be
prompted
> for username & password to login/clock- in. If no password
associated
> with these limited access users, they will not be prompted.
> > VERY important: When a user logsout, MES does NOT Clock them
OUT -
> so all labor reporting they do will continue to pile up in the
> Payroll date/shift they initially logged-in/clocked- in to.
> > Get them in the habit of Clocking Out at the end of each day or
> your supervisors will rapdily lose the ability to find and correct
> errant entries via full license Labor Entry (which is PayRoll date
> based).
> > Rob Brown
> > --- On Tue, 7/1/08, nmtaylor1969 <n.taylor@ .> wrote:
> > From: nmtaylor1969 <n.taylor@ .>
> > Subject: [Vantage] MES User Login Protocol
> > Date: Tuesday, July 1, 2008, 7:30 AM
> > We are just commencing our use of MES as part of our ongoing
> Vantage
> > implementation.
> > Can anyone tell me what the proper user configuration should be
for
> a
> > user to gain access to MES...?
> > When the user initially logs in to MES, Vantage obviously asks
for
> > their Vantage user login ( they are logging in as themselves at
> this
> > point ). The MES form is then displayed. When the user then
enters
> > their shop operator ID, it again asks them to login and then
> > complains that they are only allowed one session. I understand
the
> > logic in this, and I presume that this can be resolved within
the
> > user configuration.
> > Can sombody tell me if its normal to have the user login to
Vantage
> > and then again into MES ( i.e. the user is logged in twice ), or
> > whether it is usual / better to log into Vantage as a generic
shop
> > operator, and then into MES as themselves. Therefore only the
> generic
> > operator would require the need for mlutiple sessions.
> > Any advice would be welcome...
> > Thanks,
> > Nick Taylor
We are just commencing our use of MES as part of our ongoing Vantage
implementation.
Can anyone tell me what the proper user configuration should be for a
When the user initially logs in to MES, Vantage obviously asks for
their Vantage user login ( they are logging in as themselves at this
point ). The MES form is then displayed. When the user then enters
complains that they are only allowed one session. I understand the
logic in this, and I presume that this can be resolved within the
user configuration.
Can sombody tell me if its normal to have the user login to Vantage
whether it is usual / better to log into Vantage as a generic shop
operator, and then into MES as themselves. Therefore only the generic
Nick Taylor
We have a generic user login that is not limited to the number of
sessions it can have open. In some areas of the floor, we have it
auto-login from a terminal server connection so there is no confusion.
The only shop employees we have individual user id's are the
Inventory Control Specialists and unique operators that can issue and
return material from MES (must have AMM installed). These
individuals have their own user id's so we can track "who" made the
inventory transaction; as Vantage does not write to the PartTran
table the shop employee id...it writes the user id connected to their
shop employee.
Patty Buechler
Vantage
> implementation.
a
this
> user configuration.
generic
> Thanks,
> Nick Taylor
Thanks for the quick reply, that confirms which way we should look to
go...
Best regards,
Nick Taylor
confusion.
and
their
> shop employee.
> Thanks
> Patty Buechler
> Vantage
> > implementation.
for
> a
for
> this
enters
the
> > user configuration.
Vantage
shop
> generic
> > Thanks,
> > Nick Taylor
Hi-
We have each of our MES terminals on the shop floor set up with a unique ID
such as sf01, sf02, etc. Once the Shop Floor PC is logged into the network,
we have MES in the startup folder and it auto login using the correct
parameter in the .config file for MES. Then each shop floor employee would
just clock in/out as normal.
Hope this helps.
Randy Duly, BSBIS, MCP, A+
IT Manager
National Tube Form, LLC
A Whipp Capital Partners Company
3405 Engle Road
Fort Wayne IN 46809
P: 260-478-2363
F: 260-478-1043
H: 260-623-3390
C: 260-402-3216
Randy.duly@...
http://www.nationaltubeform.com <blocked::http://www.nationaltubeform.com/>
This e-mail transmission and any attachments to it are intended solely for
the use of the individual or entity to whom it is addressed and may contain
confidential and privileged information. If you are not the intended
recipient, your use, forwarding, printing, storing, disseminating,
distribution, or copying of this communication is prohibited. If you
received this communication in error, please notify the sender immediately
by replying to this message and delete it from your computer.
Hi Randy,
Do you need to specify a user in the MES .config file ? Are you
perhaps logging in as Manager or did you setup a specific user for
your MES logins ?
Nick
--- In vantage@yahoogroups.com, "Randy Duly" <randy.duly@...> wrote:
> Hi-
unique ID
network,
correct
employee would
> Hope this helps.
> IT Manager
> 3405 Engle Road
> Fort Wayne IN 46809
> P: 260-478-2363
> F: 260-478-1043
> H: 260-623-3390
> C: 260-402-3216
> Randy.duly@...
solely for
contain
immediately
Initially login to MES using the generic username 'shop' (psswrd 'shop').
That will allow your shop employees to enter their ID numbers in & IF their associated usernames have a password, they will be prompted for username & password to login/clock-in. If no password associated with these limited access users, they will not be prompted.
VERY important: When a user logsout, MES does NOT Clock them OUT - so all labor reporting they do will continue to pile up in the Payroll date/shift they initially logged-in/clocked-in to.
Get them in the habit of Clocking Out at the end of each day or your supervisors will rapdily lose the ability to find and correct errant entries via full license Labor Entry (which is PayRoll date based).
Rob Brown
implementation.
user configuration.
Nick Taylor
We are currently using an external time management system that is not
part of Vantage, and I am the first to admit that we have some real
accurately what they do. Funnily enough they are always very good at
recording their physical hours on site for the purposes of payroll,
but not so good at recording what they do when they are on site ;o) A
big part of our implementation is the cultural change that must take
out and all that...
experience. Problems caused by lack of procedure around the creation
of parts has come back to haunt us. We will do better next time I am
Nick
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
(psswrd 'shop').
based).
> Rob Brown
> From: nmtaylor1969 <n.taylor@...>
Vantage
> implementation.
a
this
> user configuration.
generic
> Thanks,
> Nick Taylor
Rob
out and all that...
Nick
(psswrd 'shop').
for username & password to login/clock- in. If no password associated
based).
> Rob Brown
Vantage
> implementation.
a
this
> user configuration.
generic
> Thanks,
> Nick Taylor
> Rob
not
real
at
payroll,
site ;o) A
take
> out and all that...
creation
am
> Thanks,
> Nick
> (psswrd 'shop').
prompted
associated
OUT -
> based).
> > Rob Brown
> Vantage
> > implementation.
for
> a
for
> this
enters
the
the
> > user configuration.
Vantage
shop
> generic
> > Thanks,
> > Nick Taylor
We are just about to start using MES, so I will let you know if we
encounter any problems. We are starting in just one cell with about 5-
people. How many users did you have with the same MES login ?
--- In vantage@yahoogroups.com, "Michael McWilliams"
for
anymore.
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@>
> > Rob
> > --- On Tue, 7/1/08, nmtaylor1969 <n.taylor@> wrote:
> > From: nmtaylor1969 <n.taylor@>
> not
> real
> at
> payroll,
> site ;o) A
> take
rubbish
> > out and all that...
> creation
> am
whilst
> > Thanks,
> > Nick
> > (psswrd 'shop').
in
> prompted
> associated
> OUT -
correct
date
> > based).
> > > Rob Brown
> > Vantage
> > > implementation.
> for
> > a
> for
> > this
> enters
> the
> the
> > > user configuration.
> Vantage
or
> shop
> > generic
> > > Thanks,
> > > Nick Taylor
We had 15 users logging in at different stations.
about 5-
> for
> anymore.
> > > Rob
book!! ;o)
is
> > not
> > real
good
> > at
> > payroll,
> > site ;o) A
must
> > take
> rubbish
> > > out and all that...
> > creation
time I
> > am
> whilst
> > > Thanks,
> > > Nick
> > > (psswrd 'shop').
numbers
> in
> > prompted
> > associated
> > OUT -
or
> correct
> date
> > > based).
> > > > Rob Brown
> > > Vantage
> > > > implementation.
be
> > for
> > > a
asks
> > for
at
> > > this
> > enters
understand
> > the
within
> > the
> > > > user configuration.
> > Vantage
twice ),
> or
generic
> > shop
the
> > > generic
> > > > Thanks,
> > > > Nick Taylor
