Found the post and after spending some time learning about BPM's I was able to get this working, thanks so much for getting me pointed in the right direction!
Brian
Brian
We would like Method Tracker to default to the latest approved revision when a part number is tabbed in. Currently the dialog shows earliest revision (whether approved or not approved) and the user then needs to select the desired revision from the Revision combo box.
Is there any way to change this behavior such as a company setting or a customization?
I have been working on a customization and was hoping for something simple like a "SortOrder" field on the cmbRev combo box but no such luck.
Any pointers would be appreciated.
Brian
You could sort the revs on post processing BPM. There is a post on here about how to sort the result set that I put a few months back. It should work for you
On Oct 23, 2014 8:13 PM, "brianrepman@... [vantage]" <vantage@yahoogroups.com> wrote:Â<div> <p><p><span>We would like Method Tracker to default to the latest approved revision when a part number is tabbed in. Currently the dialog shows earliest revision (whether approved or not approved) and the user then needs to select the desired revision from the Revision combo box.</span></p><p><span><br></span></p><p><span>Is there any way to change this behavior such as a company setting or a customization?</span></p><p><span><br>I have been working on a customization and was hoping for something simple like a "SortOrder" field on the cmbRev combo box but no such luck.</span></p><p><span><br></span></p><p><span>Any pointers would be appreciated.</span></p><p><span><br></span></p><p><span>Thanks,<br>Brian</span></p> </div> <div style="color:#fff;min-height:0;"></div>
