Hello guys i already made the migration from E905 to E101 but there are some customization that i need to move individually. Is there a way to migrate them individually? because when i try to export/import process i have to fix the whole C# code to make it works in Epicor 10.1.
Hi alex,
You have to do that no matter what, customizations don’t get “Upgraded” you still have to fix the C# code when you convert. Your best bet is to export / re-import and fix.
I see i though there was a work around that. Thanks for everything
It does look like that UI customizations do go through an “upgrade” procedure when migrating a database. It looks like references and namespaces are updated at a bare minimum.
This might be what the OP was making reference to…just a guess though.
It looks like the export/import process doesn’t do this…from what I’ve seen.
For some reason, I seem to remember the verify function in Customization Maintenance might also run this “process” but I don’t have access to E10 anymore to check.
JOE ROJAS
Epicor Applications Manager
VENTION MEDICAL + DESIGN & DEVELOPMENT
DIRECT: 508.597.1392 x1625 | MOBILE: 774.826.9245
