Missing Job Dates
Just one more thing.
So, now I am thinking that for some reason, some operations are being considered as WhatIf....
After playing with the problem job some more, I had ended up with three OPs - 5, 15 and 30.
OP 30 an example of one without any dates.
When I looked at the JopOper records for that job.
There was one difference that stood out - OP 30, field WIName had my userID, for the other OPs it was blank.
Data Dictionary says ---
This field is blank or contains the UserID. When not blank it indicates that the operations schedule has been changed and is considered as being in a "What If" mode.
This field is also used as part of an index which allows the system to quickly find the operations that need to be reset to "Actual Schedule".
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> > Start simple.
> Thanks, I double checked but as far as I can tell, it is none of those.
> But, that gave me some ideas.
> It seems to just get stranger:
> Job - only one operation-20, no OP start date, no OP due date and no materials have due dates.
> I added the identical operation twice as 5 and 30 and moved some of the existing materials to both.
> Rescheduled.
> Now OP 5 has a start date and its related materials have due dates.
> OPs 20 and 30, still no dates.
> (Except OP 30 does have a due date).
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@> wrote:
> > Start simple. A job won't schedule if it is for an anapproved part rev or if any resource group/resource called for as an OP Dtl is set to inactive OR if the resources an OP will be scheduled into (even if you've defined your op dtl with a resource group) is finite and you've set up with a calendar that has zero hrs.
> > ÂÂ
> > The problem is usually self inflicted.ÂÂ
> > From: Manasa Reddy <manasa@>
> > Sent: Friday, August 19, 2011 2:18 PM
> > Subject: RE: [Vantage] Re: Missing Job Dates
> > ÂÂ
> > Then what is your sequence of events?
> > We do the following:
> > 1) Unengineer (which automatically removes the release check),
> > 2) Remove from schedule
> > 3) Delete the link to the SO (or make to stock or the job)
> > 4) Make changes or delete the job entirely
> > If you are doing something different than the above, try it and see what happens. Otherwise I suspect it is something in the patch, possibly?
> > M. Manasa Reddy
> > manasa@
> > 630.806.2000 x1515
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cooner_55421
> > Sent: Friday, August 19, 2011 1:11 PM
> > Subject: [Vantage] Re: Missing Job Dates
> > >if you modify the job and don't reschedule it.
> > That's what has me stumped.
> > I've been rescheduling.
> > I've tried changing job due dates too.
> > Even removing the job from the schedule and then adding it back in.
> > I suspect there is a certain sequence that Vantage doesn't handle well and then it can't recover.
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Steven Gotschall <sgotschall@> wrote:
> > > We discovered that this happens if you modify the job and don't reschedule it.
> > > From: cooner_55421 <cooner_55421@>
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > Sent: Friday, August 19, 2011 1:01 PM
> > > Subject: [Vantage] Missing Job Dates
> > > Â
> > > Hi,
> > > In 8.03.409C, occasionally I'll find blank dates related to jobs.
> > > The jobs are firm, engineered, released and scheduled but...
> > > These fields are sometimes blank (not both fields on the same job):
> > > - JobMtl.ReqDate
> > > - JobOper.StartDate (jobOper.DueDate is populated).
> > > Wondering if anybody has run into this, or any ideas where to look?
> > > I've tried removing/adding, rescheduling (both materials and operations).
> > > Nothing I've tried makes a difference.
> > > Only clue I have is for operations,
> > > - some are added as a last op, after the job had some activity on previous ops.
> > > - For materials, I haven't find anything that might be different for those with blank req dates.
> > > Thanks
Hi,
- JobMtl.ReqDate
Â
Hi,
- JobMtl.ReqDate
> From: cooner_55421 <cooner_55421@...>
> ÂÂ
> Hi,
> - JobMtl.ReqDate
> Thanks
M. Manasa Reddy
manasa@...
630.806.2000 x1515
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Steven Gotschall <sgotschall@...> wrote:
> Â
> Hi,
> - JobMtl.ReqDate
> Thanks
Thanks, I don't think I've tried the links yet.
On a side note - 8.03.410 - is this one dead?
It's an intermittent issue that is reported to me after it has happened. So I usually don't know all the steps. For now, we list with a dashboard & handle them manually.
There is usually a reason why I can't just delete the job.
Thanks again
> M. Manasa Reddy
> manasa@...
> 630.806.2000 x1515
> > Â
> > Hi,
> > - JobMtl.ReqDate
> > Thanks
I completely understand any reason to not want to delete a job entirely.
So then try this in a test environment first...then you don't have to worry about the reasons why a job cannot be deleted entirely.
This way you will know for sure if this is the step that is screwing up the process for you.
Sorry I have absolutely no idea about patch 410.
M. Manasa Reddy
manasa@...
630.806.2000 x1515
Sent: Friday, August 19, 2011 2:33 PM
Thanks again
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Manasa Reddy" <manasa@...> wrote:
> M. Manasa Reddy
> manasa@...
> 630.806.2000 x1515
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of cooner_55421
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , Steven Gotschall <sgotschall@> wrote:
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > Â
> > Hi,
> > - JobMtl.ReqDate
> > Thanks
The last I heard about 8.03.410 was that it was slated for release in December.
Sent: Friday, August 19, 2011 3:32 PM
Â
Thanks again
> M. Manasa Reddy
> manasa@...
> 630.806.2000 x1515
> > Â
> > Hi,
> > - JobMtl.ReqDate
> > Thanks
Vantage 8.03.409C
Finally, someone else finding this an issue.
Been seeing this for some time now, including previous versions. Unable to pin-point any common variable and getting it to repeat. Right now the closest thing we have is seeing it mostly after running a Global Reschedule. In earlier versions we would see it after scheduling a Job or, as mentioned, editing a Job and then losing informaiton.
Would love to be able to make this go away.
Jeff
> Hi,
> - JobMtl.ReqDate
> Thanks
Â
Â
M. Manasa Reddy
manasa@...
630.806.2000 x1515
> Â
> Hi,
> - JobMtl.ReqDate
> Thanks
> Start simple.
Rescheduled.
> ÂÂ
> From: Manasa Reddy <manasa@...>
> ÂÂ
> M. Manasa Reddy
> manasa@...
> 630.806.2000 x1515
> > Â
> > Hi,
> > - JobMtl.ReqDate
> > Thanks
