Mobile Warehouse server setup
Can anyone share information on setting up Mobile Warehouse, How did you set it up and activate in in Epicor. We are 10.2.500. Have found all kinds of support info on the handhelds but nothing on the Epicor side. We are stumped and trying to get our Dev environment setup
The server side setup is pretty easy. Download the solution from EpicWeb and use the Solution Workbench to install.
The solution along with the install guide can be found HERE.
Nothing is linked
It’s linked to EpicWeb. You’ll need an EpicWeb login to access it.
