Hi Mike,
We experienced the exact same issue with the multiple warehouses and
we are running V8.00.809D. We originally thought that it must have
been a bug but were told by Epicor that this is the way it is meant
to be.
To overcome this problem, we generated different part numbers for
these other warehouse parts.
The reason for it is that MRP looks at the overall plant stock and
not warehouse by warehouse.
Cheers,
Jason Abramczyk
Precision Parts
to be.
Cheers,
Jason Abramczyk
Precision Parts
--- In vantage@yahoogroups.com, "Mike" <mclabaugh@...> wrote:
> Hello,
> We are running Vantage at the 6.10.541 level.
> We are currently experiencing a problem with the way we are running
> MRP and PO suggestions. We have multiple warehouses set up under a
> single plant. A number of stock components are stored at each
> location. We would like the stock level of each warehouse to be
> considered independently when we run MRP and PO suggestions.
> When we run these functions under our current configuration, we
> receive no suggestions for any of our warehouses if the stock
levels
> at either location exceeds the minimum quantity we have established
> for the part in the primary warehouse. Our intent was to have
these
> minimum quantities be considered independently by warehouse. Are
any
> of you currently able to accomplish warehouse level MRP and PO
> suggestions? Is this something that can only be independent at the
> plant level and plants need set up accordingly? Would we need to
> create different part numbers within the warehouses in order to
make
> this an independent function within a single plant? Any input
would
> be appreciated.
> Thanks in advance,
> Mike Clabaugh
> McLanahan Corporation
