Good Day Joshua:
Send them to the Epicor helpline. But would help assure a response
if you copy\pasted just the lines for that part#.
Also send a screen shot of how MRP is run.
len.hartka@...
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Joshua Giese
Sent: Tuesday, January 17, 2012 8:32 PM
To:
Subject: RE: [Vantage] Re: MRP Help
I do have the logging set to full for a while since we are just going
live.
Would it help anyone for me to post them online? I don't know how to
read
what the issue is. Who in our facility would be most qualified to read
them
and know whats going on?
Joshua Giese
Chief Technical Officer
920.437.6400 Ext. 337
*Do not follow where the path may lead. Go instead where there is no
path
and leave a trail - Harold R. McAlindon*
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
cooner_55421
Sent: Tuesday, January 17, 2012 5:03 PM
To:
Subject: [Vantage] Re: MRP Help
Have you picked advanced logging when you run MRP?
The log files will be dumped in the users report directory.
I have solved some good MRP mysteries this way.
--- In
<mailto:vantage%40yahoogroups.com> , "Joshua
Giese" <jgiese@...> wrote:
> Apparently they have stopped locking jobs and are now engineering jobs
to
> have only one resource instead of a group so they stay in place. So
job
> locking would not be the issue.
> Joshua Giese
path
[mailto:
Behalf Of
> Joshua Giese
> Sent: Tuesday, January 17, 2012 11:53 AM
> Cc: mnewell@...; jserwe@...; 'Jim
> White'
> Now that sounds more like the issue we might be having. We have locked
our
> jobs to keep MRP from moving them on us and they do go past due I
believe.
> Joshua Giese
path
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> Behalf Of
> gamcb_1
> Sent: Tuesday, January 17, 2012 10:59 AM
> Do you have your schedule locked at a past due date? If so, MRP will
ignore
> the lock and create new jobs on the correct due date.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> , "Kirstin
> Brandt" <kirstin.brandt@> wrote:
> > Where is the demand for the MRP job going? To one of the sales
orders or
> to inventory? Are both of the current jobs pointing at one of the
orders?
> Are your jobs due before the sales orders? Does your Planning
Workbench
show
> a recommendation to cancel either of the existing jobs?
> "Joshua Giese" <jgiese@> wrote:
> > > No there are two orders each for 40 that I see in the time phase,
then
> two
> > > firm jobs each for 40 putting it at 0, then a make to stock MRP
job
for
> 40
> > > that puts it at +40. Again no mins, maxs, or saftys on the part.
> > > Joshua Giese
no
> path
> Behalf Of
> > > tracy.tmat
> > > Sent: Monday, January 16, 2012 9:02 AM
> > > Might be daft but does the part have a negative on-hand qty?
> > > > We still need MRP to pick these parts up when there is demand,
we're
> just
> > > > not seeing where the demand is or why it's making extra of a
non-stock
> > > item
> > > > with no min or max make direct.
> > > > Joshua Giese
is no
> path
> > > Behalf Of
> > > > Butler, Bruce
> > > > Sent: Monday, January 16, 2012 7:51 AM
> > > > Also, if you do not want MRP to generate, you should be able to
> uncheck it
> > > > "Generate MRP" in the Part-Plants tab.
> > > > Bruce Butler, IS Manager
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > > Behalf Of tchristie1
> > > > Sent: Friday, January 13, 2012 3:25 PM
> > > > Since the part is non-stock, a sales order release for this part
will
> > > > default to "Make Direct". Unless the created firmed jobs are
linked
to
> > > that
> > > > release MRP will plan a new one linked to the Sales Order
Release. I
> would
> > > > check there first.
> > > > <mailto:vantage%40yahoogroups.com>, "Anon" <jgiese@> wrote:
> > > > > Anyone really good with MRP out there that might be able to
help
us
> > > > understand why we are getting jobs we do not expect. The
scenario is
> we
> > > have
> > > > part ABC. It is a non-stock item with no mins or maxs. We do not
want
> to
> > > > hold stock of it. A job we do not expect to see on the schedule
for
a
> qty
> > > of
> > > > 40 is showing up. There are two orders in for the part both at a
qty
> of 40
> > > > and two firmed jobs both for a qty of 40 as we do expect. Why is
the
> > > system
> > > > generating this 3rd MRP job for 40 when there is no demand. Only
one
> of
> > > the
> > > > firmed jobs is complete, the other is release. MRP should see
this
> though
> > > > and know that the demand is spoken for correct? I hope some of
that
> made
> > > > sense. Please poke at me for more detail or specific details if
> needed.
> > > > [Non-text portions of this message have been removed]
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
