MRP process is auto Cancelled
Hello experts,
We have recently upgrade epicor from 9.05.702 to 10.1.500. While running the MRP process, the task agent (or who :blush: but not the user ) auto cancelling the MRP process. The important thing is it is auto cancelled after 59 Minuites (Strang :triumph:)…Error : Program Cancelled
I have re-checked all TimeOut properties for task agent, buyer for MRP, MRP setup in Site Maintainance…
Has anybody experienced this issue before?
I would try to run it again, but turn logging on to give you more information.
@Beth : I have already tried for thrice…n same results found. Why it is auto cancelled after 59 minuites for all 3 times…? i think it is the result of wrong setup for MRP ?
MRP run with one scheduler will keep trying for one hour after it hits an
error.
If you run it with two schedulers then the second scheduler may keep going,
unless it too hits an error.
Run the logs in full detail mode and you need to track down the error.
Support should help with this if you are having trouble reading the logs.
Brad
Hi Brad,
I tried to read this log in details, but not found any related soution,
Have a look…
ERP101500: An error occurred trying to run task ID 69354 for agent SystemTaskAgent on the application server (User: PRA, Task Description: Process MRP).
Error Detail:
Business Logic Error
Business Layer Exception
BusinessObjectException
Description: PROGRAM CANCELLED
Program: Ice.Services.Lib.RunTask.dll
Method: InnerRunTask
Line Number: 583
Column Number: 25
Server Trace Stack: at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_Releases\ICE\3.1.500.15\Source\Server\Services\Lib\RunTask\RunTask.cs:line 583
at Ice.Services.Lib.RunTaskSvc.RunTask(Int64 ipTaskNum) in C:_Releases\ICE\3.1.500.15\Source\Server\Services\Lib\RunTask\RunTask.cs:line 299
at Ice.Services.Lib.RunTaskSvcFacade.RunTask(Int64 ipTaskNum) in C:_Releases\ICE\3.1.500.15\Source\Server\Services\Lib\RunTask\RunTaskSvcFacade.cs:line 87
at SyncInvokeRunTask(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.Wcf.EpiOperationInvoker.<>c__DisplayClass3_0.b__0(Object instance_ex) in C:_Releases\ICE\3.1.500.15\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 25
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:\_Releases\ICE\3.1.500.15\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59 at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in C:_Releases\ICE\3.1.500.15\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:_Releases\ICE\3.1.500.15\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage41(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage4(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage31(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage3(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage2(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage1(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.ServiceModel.Channels.StreamConnection.OnRead(IAsyncResult result)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.ServiceModel.Channels.SocketConnection.FinishRead()
at System.ServiceModel.Channels.SocketConnection.OnReceiveAsync(Object sender, SocketAsyncEventArgs eventArgs)
at System.ServiceModel.Channels.SocketConnection.OnReceiveAsyncCompleted(Object sender, SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
I think scheduling issue shoul b there…
