Hello we seem to have everything set up for inter company but when we run the process we get this issue when opening the suggestions.
Business Layer Exception
No currency conversion exchange records were found when trying to convert amount from currency code to currency code PLN.
Error Detail
Correlation ID: 4f71b8b5-34a3-4650-b100-b8201cebee2f
Description: No currency conversion exchange records were found when trying to convert amount from currency code to currency code PLN.
Program: Erp.Internal.Lib.Shared.dll
Method: ConvertAmt
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet dataSets)
at Erp.Proxy.BO.SOPOLinkImpl.CustomGetByID(String incomingOutgoing, Int32 iCPONum, Int32 intQueID)
at Erp.Adapters.SOPOLinkAdapter.CustomGetByID(String incomingOutgoing, Int32 ICPONum, Int32 intQueOut)
at Erp.UI.App.IncomingICPOSugEntry.Transaction.adapterGetByID(String id, Int32 intQueID)
What is the currency code for the document in the sending company?
What is the base/reporting currencies in the receiving company?
What is the Rate Group assigned to the document and also the receiving company default?
Are the exchange rates for this rate group and for all currencies setup?
