Need Help Adding RDD
Thanks to all for help with this.
I finally figured out what I was doing wrong.
I'm never done this before, but now with your help I have learned how.
My mistake was:
In Report Maintenance > Under the Custom Report Style I created, I had not chosen the correct Data Definition.
That was the reason it never was seen in the XML.
Several of you suggested this late yesterday, but with a fresh mind today, I realized what you were meaning.
Thanks to all for your assistance.
Jim Moore
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karen Schoenung
Sent: Tuesday, June 18, 2013 8:17 AM
Subject: RE: [Vantage] Need Help Adding RDD
Did you search the actual XML file in your reports directory to see if the fields are output? If not, I have found sometimes I have had to output the FULL table to get the fields output...(move all fields to included)
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Cathy
Sent: Monday, June 17, 2013 7:32 PM
I don't know why it isn't showing up in the XML - that is the strange part.
In Crystal did you Set Datasource location to your new XML file?
Then under Database - verify Database?
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
james.moore@...<mailto:james.moore%40gd-ots.com><mailto:james.moore%40gd-ots.com>
Sent: Monday, June 17, 2013 1:48 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Yes, I pointed to the duplicate of SubCPack that I created as a new report
style called CustomSubCPack.rpt and made it the default before running /
previewing Subcontractor Shipment Entry.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Cathy
Sent: Monday, June 17, 2013 3:39 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Since it is not in the XML, did you change the Data Definition under
Company > Report Style > SubCPack?
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
james.moore@...<mailto:james.moore%40gd-ots.com><mailto:james.moore%40gd-ots.com> <mailto:james.moore%40gd-ots.com>
Sent: Monday, June 17, 2013 1:02 PM
Subject: [Vantage] Need Help Adding RDD
I'm trying to add Character01 and Date01 from SubShipH to a duplicate I made
of SubCPack.
I want to report off of these two added fields from the customization I
added to Subcontractor Shipment Entry.
I have added those fields from the excluded to included area in RDD, but I
don't see them in Crystal to add or in the XML that is created.
What steps should I take to do this?
Epicor 9.04.507A
Jim Moore
I'm trying to add Character01 and Date01 from SubShipH to a duplicate I made of SubCPack.
I want to report off of these two added fields from the customization I added to Subcontractor Shipment Entry.
I have added those fields from the excluded to included area in RDD, but I don't see them in Crystal to add or in the XML that is created.
Epicor 9.04.507A
Jim Moore
james.moore@...
of SubCPack.
Epicor 9.04.507A
Jim Moore
Yes, I pointed to the duplicate of SubCPack that I created as a new report style called CustomSubCPack.rpt and made it the default before running / previewing Subcontractor Shipment Entry.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cathy
of SubCPack.
Epicor 9.04.507A
Jim Moore
Jim,
Â
Is the report style you are using tied to this new RDD in which you added the UD fields ?
Sent: Monday, June 17, 2013 3:02 PM
Â
Epicor 9.04.507A
Jim Moore
Yes it is.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of P.M.
Sent: Monday, June 17, 2013 3:59 PM
Subject: Re: [Vantage] Need Help Adding RDD
Jim,
From: "james.moore@...<mailto:james.moore%40gd-ots.com>" <james.moore@...<mailto:james.moore%40gd-ots.com>>
Epicor 9.04.507A
Jim Moore
james.moore@...
Behalf Of Cathy
Behalf Of
james.moore@... <mailto:james.moore%40gd-ots.com>
of SubCPack.
Epicor 9.04.507A
Jim Moore
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Cathy
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Behalf Of
james.moore@...<mailto:james.moore%40gd-ots.com> <mailto:james.moore%40gd-ots.com>
of SubCPack.
Epicor 9.04.507A
Jim Moore
