"No records selected" error on Dashboard Autoprint
Hello all,
I have a BAQ report (a label), that I have setup to print from a dashboard with a checkbox. It works fine. Sometimes. Other times, frequently, when I trigger the report, I get a “no records selected” error. There doesn’t seem to be any rhyme or reason to it.
This is the BAQ. It has 2 parameters set (I originally started with only KEY1 as parameter but added KEY5 when I encountered this issue):
I have set these fields as “Options” in the BAQ report builder. I have set my parameters on the data directive.
I can’t figure out what my issue is. Sometimes the report generates fine…hmmm.
Any input would be awesome. Thank you!
Alice
So with two parameters they must both be true.
Is the “Skip Condition when empty” box selected on either parameter?
Hi there,
I actually feel like I should be able to make this work with one parameter, as I had originally thought. KEY 1 is a datetime stamp that is set by BPM when a new record is added to UD20. Since they are all unique vales, am I right in thinking this should pass the dashboard line to the report every time?
The “skip condition” box is not checked, as there should always be a value set for KEY1.
What about Key5? Is its “Skip Condition…” checked?
Neither were checked. KEY 5 is jobNum which should also pass a value every time. But really, I dont see why I need more than one parameter. I just took off KEY 5 and am trying to troubleshoot with KEY 1 only. The report will generate for a line (or not) and then the same one wont generate if I come back 2 minutes later. Its a conundrum, as I was hoping to go live with this next week. But its wobbly.
Is it possible that all KEYs for the UD table need to be parameters?
