If you "Hide Screen Saver tab" in the local policy, that should slow them down a bit. They could still go into the registry and manually change it there, but if the tab isn't available at the display. I actually use the "Remove Display in Control Panel" option and don't let them mess with anything. And if they do manage to change something, I have a program that runs when the computer logs into the network that sets all the settings the way I want them.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Paul V. Blais
Sent: Friday, May 30, 2008 1:01 PM
Subject: [Vantage] O/T - Locking in to "My Pictures" screensaver
XP Pro, we want to set every MES computer with the same screensaver. We
put the pictures we want out on the network and set each screensaver to
that location, but how can you lock people out for changing the
location? I can lock the screensaver in by setting a local policy but
that still let's them change the settings on it.
Thanks in advance,
Paul
Thanks in advance,
Paul
