Morning All,
This appears to be a bug with custom code on adding a field to grid. We are adding part data to PO Suggestions. We added the following code. Then when we select the entire row of the grid and close out of the window we get the below error. If we select a cell in the grid there is no error.
If I comment out the grdMatParts lines, no error occurs.
Anyone else see this before, any tricks to get around it.
public class Script
EpiUltraGrid gridMatParts;
public void InitializeCustomCode( )
SetExtendedProperties( );
gridMatParts = ( ( Ice.Lib.Framework.EpiUltraGrid )csm.GetNativeControlReference( "4d59326f-7a76-4c5c-8e2c-54e630db64da" ) );
gridMatParts.DisplayLayout.Bands[ 0 ].Columns.Add( "PartLookupDNBType_c", "Buyer Status" );
gridMatParts.InitializeRow += new Infragistics.Win.UltraWinGrid.InitializeRowEventHandler( grdTPLst_InitializeRow );
Application Error
Exception caught in: Ice.Lib.EpiClientLib
Error Detail
Message: Object reference not set to an instance of an object.
Program: Ice.Lib.EpiClientLib.dll
Method: TrackLastActiveGrid
Client Stack Trace
at Ice.Lib.Framework.EpiUltraGrid.TrackLastActiveGrid()
at Ice.Lib.Framework.EpiUltraGrid.afterSelected(Object sender, AfterSelectChangeEventArgs ea)
at Infragistics.Win.UltraWinGrid.UltraGrid.OnAfterSelectChange(AfterSelectChangeEventArgs e)
at Infragistics.Win.UltraWinGrid.UltraGrid.FireEvent(GridEventIds id, EventArgs e)
at Infragistics.Win.UltraWinGrid.UltraGrid.SelectNewSelection(Type type, Selected selected)
at Infragistics.Win.UltraWinGrid.UltraGrid.ClearSelectedRows()
at Infragistics.Win.UltraWinGrid.SelectedRowsCollection.Clear()
at Infragistics.Win.UltraWinGrid.UltraGridBase.Set_ListManager(Object newDataSource, String newDataMember)
at Infragistics.Win.UltraWinGrid.UltraGridBase.set_DataSource(Object value)
at Infragistics.Win.UltraWinGrid.UltraGridBase.DataSource_Disposed(Object sender, EventArgs e)
at System.ComponentModel.Component.Dispose(Boolean disposing)
at System.Windows.Forms.BindingSource.Dispose(Boolean disposing)
at System.ComponentModel.Component.Dispose()
at Ice.Lib.Framework.EpiUltraGrid.Dispose(Boolean disposing)
at System.Windows.Forms.Control.Dispose(Boolean disposing)
at Ice.Lib.Framework.EpiUserControl.Dispose(Boolean disposing)
at Ice.Lib.Framework.EpiBasePanel.Dispose(Boolean disposing)
at Erp.UI.App.POSuggEntry.MaterialListPanel.Dispose(Boolean disposing)
at Infragistics.Win.ManagedContainerControlBase.Dispose(Boolean disposing)
at Infragistics.Win.UltraWinDock.UltraDockManager.DestroyControl(Control control)
at Infragistics.Win.UltraWinDock.UltraDockManager.RemoveControlPaneContainer(DockableControlPane pane)
at Infragistics.Win.UltraWinDock.UltraDockManager.UninitializeComponent()
at Infragistics.Win.UltraWinDock.UltraDockManager.set_HostControl(ContainerControl value)
at Infragistics.Win.UltraWinDock.UltraDockManager.Dispose(Boolean disposing)
at System.ComponentModel.Container.Dispose(Boolean disposing)
at System.ComponentModel.Container.Dispose()
at Ice.Lib.Framework.EpiDockManagerPanel.Dispose(Boolean disposing)
at Erp.UI.App.POSuggEntry.Panels.MainPanel.Dispose(Boolean disposing)
at Erp.UI.App.POSuggEntry.POSuggEntryForm.Dispose(Boolean disposing)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at Ice.Lib.Framework.EpiForm.WndProc(Message& message)
