ODBC for Payroll in Vantage 8.03
That did it. That created the EMPLINK data in the empmaster table that then would link up with the PRChkDtl EMPLINK. Thank you SO much!
Mike..
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> Go to payroll employee maint.
> In the actions menu there is an option for 'generate employee links'. This
> will create the links between the tables and populate the empty fields.
> You'll need to re-run this anytime you add/remove employees.
> I believe they do this so that normal users with BAQ access can't get into
> PR info. At least I recall hearing that somewhere.
> On Mon, Jun 4, 2012 at 1:09 PM, Vic Drecchio <vic.drecchio@...>wrote:
> > Out of curiosity I checked the Training DB. EmpLink is populated in PRCheck
> > and PRChkDtl but not in PREmpMas.
> > The Data Dictionary says it's usually blank.... so that's useless. In fact
> > it says for PREmpMas.EmpLink: ".This field is normally blank, which means
> > file joins are impossible. This value can be set/reset only by the payroll
> > manager via an option in system maintenance."
> > Hmm.. This is a good question.
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of
> > Vic Drecchio
> > Sent: Monday, June 04, 2012 12:54 PM
> > Subject: RE: [Vantage] Re: ODBC for Payroll in Vantage 8.03
> > Sorry, hit SEND too quickly.
> > That EmpLink field is in both tables.
> > If I recall correctly there is a PREmpMas table. It's an extension of
> > EmpBasic. but it has your EmpLink field.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> > Behalf Of
> > flexial_ma
> > Sent: Monday, June 04, 2012 12:45 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Re: ODBC for Payroll in Vantage 8.03
> > I'm actually looking at PRChkDtl and PRCheck and I've got them working now
> > but I cannot figure out what to link to find out the ID of the employee the
> > check is written for. I see the EMPLINK field but it doesn't link back to
> > anywhere I can find a EMPID for. Any ideas?
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > <mailto:vantage%40yahoogroups.com> , "Vic
> > Drecchio" <vic.drecchio@> wrote:
> > > Are you looking for LaborHed and LaborDtl?
> > Behalf Of
> > > Mike Abell
> > > Sent: Monday, June 04, 2012 9:41 AM
> > > Subject: RE: [Vantage] ODBC for Payroll in Vantage 8.03
> > > No, just when I look in the payroll type tables, there's nothing in there
> > > shown and I expected there to be some which led me to believe that
> > "maybe"
> > > it just wasn't letting me access them.
> > > -----Original Message-----
> > > Behalf Of Jose Gomez
> > > Sent: Monday, June 04, 2012 8:38 AM
> > > Subject: Re: [Vantage] ODBC for Payroll in Vantage 8.03
> > > It should allow you to access ANY tables within Progress. Are you getting
> > a
> > > specific error?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > *checkout my new blog <http://www.usdoingstuff.com> *
> > > *T: 904.469.1524 mobile
> > > E: jose@ <mailto:jose%40josecgomez.com>
> > > http://www.josecgomez.com
> > > <http://www.linkedin.com/in/josecgomez>
> > <http://www.facebook.com/josegomez>
> > > <http://www.google.com/profiles/jose.gomez> <
> > http://www.twitter.com/joc85>
> > > <http://www.josecgomez.com/professional-resume/>
> > > <http://www.josecgomez.com/feed/>
> > > *Quis custodiet ipsos custodes?*
> > > On Mon, Jun 4, 2012 at 9:34 AM, flexial_ma <mike.abell@
> > <mailto:mike.abell@%0b%3cmailto:mike.abell@%0b>
> > <mailto:mike.abell@%0b>
> > > <mailto:mike.abell%40kingston-asfc.com> >wrote:
> > > > I am needing to create some reports using ODBC that use the payroll
> > > > tables in Vantage. We are on Progress 10.1. I have the sysprogress
> > > > user setup and all and it's working but I don't believe that allows me
> > > > to access the payroll tables in the Vantage database. I'm using
> > > > Crystal Reports outside of Vantage using ODBC as this is my prefereed
> > > method for designing reports.
> > > > Thanks!
> > > > Mike..
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have
> > > already linked your email address to a yahoo id to enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > > Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > <http://groups.yahoo.com/group/vantage/files/>
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > No virus found in this message.
> > > Checked by AVG - www.avg.com
> > > Version: 2012.0.2178 / Virus Database: 2425/5044 - Release Date: 06/04/12
> *John Driggers*
> *High End Dev, System Design, Profit Drinking*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
I am needing to create some reports using ODBC that use the payroll tables in Vantage. We are on Progress 10.1. I have the sysprogress user setup and all and it's working but I don't believe that allows me to access the payroll tables in the Vantage database. I'm using Crystal Reports outside of Vantage using ODBC as this is my prefereed method for designing reports. Thanks!
Mike..
It should allow you to access ANY tables within Progress. Are you getting a
specific error?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks!
> Mike..
No, just when I look in the payroll type tables, there's nothing in there shown and I expected there to be some which led me to believe that "maybe" it just wasn't letting me access them.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
It should allow you to access ANY tables within Progress. Are you getting a specific error?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks!
> Mike..
What table specifically are you looking at?>
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Of Jose Gomez
> a specific error?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks!
> > Mike..
Mike Abell
specific error?
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com>
> Thanks!
> Mike..
I'm actually looking at PRChkDtl and PRCheck and I've got them working now but I cannot figure out what to link to find out the ID of the employee the check is written for. I see the EMPLINK field but it doesn't link back to anywhere I can find a EMPID for. Any ideas?
> Mike Abell
> specific error?
> *Jose C Gomez*
> *Software Engineer*
> > Thanks!
> > Mike..
EmpBasic
flexial_ma
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
Behalf Of
> Mike Abell
a
> specific error?
> *Jose C Gomez*
> *Software Engineer*
<mailto:mike.abell@...%0b>
> > Thanks!
> > Mike..
flexial_ma
Behalf Of
> Mike Abell
a
> specific error?
> *Jose C Gomez*
> *Software Engineer*
> > Thanks!
> > Mike..
Yea I figured that one but in the PREmpMAS, the EMPLink field is empty....
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Monday, June 04, 2012 11:54 AM
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
flexial_ma
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "Vic
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
> Mike Abell
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
a
> specific error?
> *Jose C Gomez*
> *Software Engineer*
<mailto:mike.abell@...%0b<mailto:mike.abell@...%0b%3cmailto:mike.abell@...%0b>>
> > Thanks!
> > Mike..
> http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> Checked by AVG - www.avg.com<http://www.avg.com>
Vic Drecchio
Behalf Of
flexial_ma
Behalf Of
> Mike Abell
a
> specific error?
> *Jose C Gomez*
> *Software Engineer*
> > Thanks!
> > Mike..
> Of
> Vic Drecchio
> Behalf Of
> flexial_ma
> Behalf Of
> > Mike Abell
> "maybe"
> a
> > specific error?
> > *Jose C Gomez*
> > *Software Engineer*
> > > Thanks!
> > > Mike..
> have
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
