I installed 8.5 first (as recommended by Crystal) and then I installed the
downgrade they sell for $35.00 to 8.0. ODBC, Crystal and Vantage 5.0 seem to
work fine. It is Access2002 the one I have the ODBC fail calls and
corruptions.
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Sent: Friday, November 09, 2001 10:55 AM
Subject: Re: [Vantage] 5.0 - ODBC?
What did you install - Crystal 8 or Vantage 5.1??
Troy Funte
Liberty Electronics
corruptions.
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Friday, November 09, 2001 12:00 PM
Subject: RE: [Vantage] 5.0 - ODBC?
I just finish installing it and run a report with a table containing 21k
and
some record. It worked fine. I am testing it now in the server and see how
it performs.
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Sent: Friday, November 09, 2001 10:05 AM
To: 'vantage@yahoogroups.com'
>install Crystal 8.5 and downgrade to 8.0
It may be best to uninstall crystal entirely before putting another
version
on your PC. I installed 8.0 over 7.0, and ended up having to reformat
before it worked entirely.
Thaddeus
Sent: Friday, November 09, 2001 8:07 AM
I have 523 mgs of mem, Pentium 4 at 1400 MHz. The server and network are
not
that sophisticated. I will keep you posted when I receive and install 5.1
and 9.1C. We need ODBC to be more stable because we use Access to
"massage"
the data used for EDI. I will install Crystal 8.5 and downgrade to 8.0 to
see how ODBC behaves. Maybe, it will be better (or worse)...
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Sent: Thursday, November 08, 2001 6:37 PM
Do you think it is a memory issue? I've know Excel to blow up when there
is
too much info coming in. I really don't have any other clues. Do you
have
access to the Merant ODBC driver? I'd be curious whether that works
better.
Troy Funte
Liberty Electronics
Sent: Thursday, November 08, 2001 6:31 PM
I AM USING WIN2000 AND ACCESS 2002. THE LINKS WORK FINE UNTIL THE
RECORDS
APPROACH 7000 TO 8000 RECORDS. I WOULD LIKE TO RE-START AND DO ONLY THE
LENGTH OF INDEX DESCRIPTION FIX. I WAS ABLE TO READ TABLES WITH MORE
RECORDS
AND DID NOT HAVE TO ENTER PASSWORDS WHEN LINKING TABLES. I AM ALSO
WAITING
FOR 5.1. WE ARE PREPARING TO JUMP FROM 4.0 TO 5.1. I HEARD 9.1C DRIVERS
ARE
MORE STABLE...
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Sent: Thursday, November 08, 2001 4:50 PM
Mario,
Are you getting the error in Crystal or Access or Excel, or what?
(about the corrupt tables).
Troy Funte
Liberty Electronics
Sent: Thursday, November 08, 2001 3:53 PM
This was one of the documents I used to connect to ODBC. Since then, I
have
applied all fixes (.r's) and follow all instructions. I am still
having
the
problem that if a table has more than 7000 or 8000 records, I get an
ODBC
failed error message and corrupt the table.
How to connect an ODBC Client to eManufacturing database
Go to your ODBC Datasource Admininstrator in the Control Panel.
If you don't see the driver
MERANT 3.60 32-Bit Progress SQL92 v9.1A
Under User DSN, You will need to add it by choosing the Add button and
finding the above mentioned driver and then choose finish.
The next screen will be the configuration screen
Enter the Data Source Name -- Progress 9.1A ODBC
Enter the Description -- eManufacturing by Epicor
Enter the Host Name -- (Name of your Server)
Enter the port Number associated with the Database -- (Located in your
services file)
Enter the Database Name -- vantage
Enter User ID - sysprogress
No password is needed
Try clicking on the test connect button and then OK
You should get a message saying Connection established.
Mario Aguirre
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Sent: Thursday, November 08, 2001 8:07 AM
I would love it if you didn't need a password, but all that I've read
says
it's required - and is built into the SQL-92 drivers. If anyone can
get
it
working otherwise, PLEASE let me know. It seems to me that Jay
Erickson's
instructions of imbedding the password in the ODBC configuration file
was
meant to work with programs like Access and Excel, but not with
Crystal.
Troy Funte
Liberty Electronics
Sent: Wednesday, November 07, 2001 11:22 AM
Do you mean the user ID? Sysprogress should be the user ID and
password
should be clear. I set up the client (with the user id) and the ODBC
settings in Progress Explorer following the instructions and
installing
all
patches. Whenever an ODBC link is used, ODBC will call the connect
window
and clicking OK should be enough.
Did you assign a password to user id sysprogress?
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
[mailto:sarah.vareschi@...]
Sent: Wednesday, November 07, 2001 9:13 AM
With the new ODBC, is there a ways to shut-off the password so that
users
running reports don't have to type it in each time they run access a
database or reports?
Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
have
(1) To access the Files Section of our Yahoo!Group for Report
Builder
and
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Yahoo! Groups Sponsor
ADVERTISEMENT
must
have already linked your email address to a yahoo id to enable access.
Builder
and
have
and
ADVERTISEMENT
and
have
and
ADVERTISEMENT
and
have
have
have
ADVERTISEMENT
