Eric,
I still don't understand why you need to have the local account....
If the user logs on to the domain account then you shouldn't have any
problems with the files on the server.
The server doesn't look at the username when figuring out whether to allow
access to files; its looking at the SID (security ID - a unique number
assigned to the user account). Since the local account is separate from the
domain account, they both have different SIDs even though they have the same
username.
Try logging in at the workstation by pointing to the domain rather than the
workstation account and see if you can access the files.
Steve Sanders
Delta Centrifugal Corp.
e.tolliver@...]
Sent: Friday, November 10, 2000 10:38 AM
To:
vantage@egroups.com
Subject: RE: [Vantage] Off Topic Nt Users
Steve,
We are running an Member Server so The name and password on the server
need
to match the name and password on the users system.
Eric Tolliver
IT\MIS
Continental Industries Inc.
5456 E. Mcdowell Rd.
Mesa, Az 85215
http://ciirelays.com/
mailto:
e.tolliver@...
ssanders@...]
I'm not sure why you want/need to have the account on the workstation, but
if you are logging in to the local account and then trying to access
resources on the server that have permissions for the domain account then
that will not work because the network sees them as two separate accounts.
The only account we have on our workstations is the Administrator account
(for emergencies where we can't logon to the network). Otherwise, all
accounts are domain objects and there is little or no confusion about
which
account is being used.
Hopefully I haven't misread your message. Hope this helps.
Steve Sanders
eGroups Sponsor
please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
