Thanks for the suggestions.
I have settled on the following....
- InFocus IN36 3000 lumen projector
- InFocus LiteShow II Wireless Presentation Adaptor
- Bretford Flush Universal Projector Mount
The mount "hangs" down only 6" from the ceiling but allows swivel adjustment for aiming. We will need to reenforce from above the suspended ceiling panels. Sometimes it's handy to work in a metal fab environment....lots of clever people around for such tasks.
I am taking a chance on the wireless part to avoid wiring labor and materials. We will however run power to a support column a few feet from where the projector will be located. Our maintenance guys are vey good at this. If the wireless does not work out quality wise I will resort running wire.
This will be in our training room which seats 200 or so. Phase II will be a PA system in the room with a multi-source mixer and wireless microphones. The currently diconnected paging speakers in the ceiling should suffice if I can tap into their line.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jason Claggett
Sent: Friday, September 14, 2007 7:19 AM
Subject: RE: [Vantage] Off Topic - Projectors
Todd,
1. Great idea. Should work great...never tried it before, but
great idea. Let me know how this turns out as I might implement this.
2. Should be okay to do this. Depending on what type of projector
you are getting you may consider running RGB lines for HD quality??
3. We use the pole type and attached it to the beam/girder above
the ceiling and put a 1" hole through one of the tiles and it hangs down
about 2" from the drop ceiling - very professional looking. Make sure
you leave enough room for the cables.
4. Not sure
5. Something not mentioned would be power considerations. If you
are hanging this in a boardroom you may need to put a separate
receptacle above the ceiling as fire marshals usually frown upon 50'
foot extension cords thrown across the top of ceiling tiles :-).
Luckily, the person I was working with used to do this for a living so
he ran a new line and it was no problem.
Hopefully this helps in your decision making process.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@...<mailto:jason%402wtech.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Todd Caughey
Sent: Monday, September 10, 2007 12:01 PM
Little did I know a couple weeks ago I would need this thread. Yesterday
on the way back from a mgmt retreat our president suddenly asked me to
ceiling mount a projector in our training room and finally put in a room
PA system. I have a couple questions for the more experienced projector
users...
1. I have an old 4 port KVM. Any reason I could not use it as a video
only switch for multiple sources?
2. I would like to limit the cables to run, maybe just one VGA...anyone
using a video to VGA convertor for things like DVD players?
3. Any recommendations for ceiling mount for a typical suspended panel
ceiling environment? I've seen the "pole" type but these are better for
over boardroom tables, etc.... and hang too low in an open space with a
low ceiling.
4. For models with ethernet....do these require software on the PC for
performing projector control fuctions? Can the network interface be used
for the source signal to be projected?
Todd Caughey
Harvey Vogel Mfg. Co.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of RSN
Sent: Tuesday, August 28, 2007 10:03 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: Re: [Vantage] Off Topic - Projectors
Lori- Please check with Infocus (portland/Wilsonville, OR). They make
great quality projectors.
RSN
----- Original Message ----
From: Lori Gustafson <lori.gustafson@...<mailto:lori.gustafson%40precision-inc.com>
<mailto:lori.gustafson%40precision-inc.com>>
Sent: Friday, August 24, 2007 9:23:24 AM
Subject: [Vantage] Off Topic - Projectors
We are looking to install a ceiling mounted projector in our conference
room and I was wondering if any one could recommend a brand or give any
helpful advise as what to look for in a projector. We would want it to
be wireless and remote controlled if possible.
Any input would be greatly appreciated.
Lori Gustafson
Information Resources
Precision, Inc.
763-852-6718
__________________________________________________________
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
The information contained in this E-mail message and any documents which
may be attached are privileged and confidential, and may be protected
from disclosure.
Please be aware that any use, printing, copying, disclosure or
dissemination of this communication may be subject to legal restriction
or sanction. If you think you have received this message in error,
please reply to the sender.
For more information please visit www.harveyvogel.com
The information contained in this E-mail message and any documents which may be attached are privileged and confidential, and may be protected from disclosure.
Please be aware that any use, printing, copying, disclosure or dissemination of this communication may be subject to legal restriction or sanction. If you think you have received this message in error, please reply to the sender.
-Todd C.
Todd,
4. Not sure
Jason Claggett
MCP #3856159
312.533.4033 x8039
Of Todd Caughey
users...
low ceiling.
Todd Caughey
Behalf Of RSN
RSN
Lori Gustafson
Precision, Inc.
763-852-6718
from disclosure.
