On Cadence Kinetic Cloud and SSRS
My method works until Kinetic is fixed --or they kill Classic-- which ever comes first :rofl::
  • Use Classic design-for-report to edit/preview the SSRS --Until recently the Publish option worked but since it’s broke:
  • Use Classic Report Style maintenance to upload the finished SSRS
That’s such a tedious way to do it and you can’t preview changes. This works for simple tweaks like logo changes but for something complex or a totally new report this is a non-starter.
Randy do you ever use the design for ssrs and download functionality where you can preview changes without having to upload it?
@utaylor yup, two posts above you
:winking_face_with_tongue:
So, here’s a DevOps fever dream I had. Imagine:
PowerShell 7.5.3
PS C:\Users\mwonsil> dotnet new SSRSReport
>> Based on Current Report? OrderAck
>> Report Style? SSRS
>> Modify RDD? Yes
>> RDD Based On? OrderAck
>> New RDD Name? OrderAck2
>> New Repository? Yes
>> Repository URL? htts://github.com/kineticize/reports/OrderAck2
>> Deploy to Environment? Pilot
>> Ready(Y/n)? Y
The template would use REST to:
  • create a new report style
  • copy down the SSRS RDL, import it into GitHub
  • Duplicate the RDD
  • Create a GitHub Action that upon COMMIT will deploy the SSRS to Pilot (extracting the SSRS from the repo, zipping it up, upload, execute the report with known parameters)
So, every time you commit, it performs all the steps that @brendanphilbin outlined above. Time could be saved if the test run used a known GUID with pre-loaded test data.
And then I woke up…
Printing the report as ā€œGenerate For Designā€, then using ā€œDesign SSRSā€ in System Monitor was a great method but doesn’t work currently in Kinetic and Classic was working but started throwing errors when trying to publish.
Oh wait, I forgot about the part where I did the pull-request and it took the last commit and published it to production. Now I have a full history of all changes I made and can easily publish to any instance. Even the test data could be in the repo…and there was even more…
Time To Wake Up GIF by Cloie Wyatt Taylor
That’d be great but at a minimum I’d be happy if they just fixed their Kinetic UI and made it work like Classic used to.
Nice. Had a very similar dream for copy, transform source to xml, publish to Bold Reports but didn’t work out.
It seems everyones env has different symptoms. FWIW, mine is working in Kinectic Browser all except publish. But I can zip and upload via Report Style - still kinetic.
2025.1 or before was like:
  • Kinetic report > generate for design
  • Sys Monitor (classic) > Design SSRS Report
  • SSRS Report Design (classic) > DL ( DL and launches MSReport Builder in one step)
  • Edit n save RDL
  • SSRS Report Design(classic) > Preview (launches pdf w changes)
2025.1 (back in may, after edge agent update not sure which patch) was like:
  • Sys Monitor (Kinetic) > Design SSRS Report
  • SSRS Report Design (kinetic) > Download (Downloads n unzips - via Edge Agent)
  • SSRS Report Design (kinetic) > Design (launches MSRptBuilder w RDL**)
  • Edit n save RDL
  • SSRS Report Design (kinetic) > Preview (launches pdf in local browser w changes)
  • SSRS Report Design (kinetic) > Publish > ERROR
  • Report Style > Upload .zip > SUCCESS
Just tested and that’s still the story in our env. So we can do all things in Kinectic. Publish isn’t single click but preview is working.
**PS - This is the worst part - behind every window on some random monitor. LOL
Just got this from support for cloud customers:
We no longer can use custom report names (e.g. JobTravCoV2), have to use the names that were downloaded in the zip. You have to make a copy of the out-of-box report style and use that download as a starting point.
If you need to add a subreport, create an EpicCare ticket. The subreport name shouldn’t have special characters (e.g. CoPartDataSub, not CoPartData-Sub)
Hope that helps others - it’s been a bit of a frustrating journey for us.
Jenn
Thanks for more info on this.
A couple of things.
First, I whipped up a how-to on download/upload for RDLs from Kinetic 2025.2.5, FWIW. The procedure isn’t too onerous.
How To Download Edit and Upload SSRS Reports In Kinetic.docx (423.0 KB)
And when an RDL mysteriously stopped changing/uploading, I created a new report style and changed the folder name within Custom Reports on the popup in Report Style, per suggestion from Epicare. In this case, I was working with an order acknowledgment, so I changed the folder from SalesOrderAcknowledgment to SalesOrderAcknowledgment2. It has worked since.
Note that I copied from the standard base style and then changed the RDD and RDL names accordingly. I can’t say if that’s significant.
Your mileage may vary.
Joe
Thanks Joe!
