There should be a routine in the Epic51\Vantage folder called BACKVN.BAT that runs vntgbkup in online mode. The guts of backvan.bat are:
echo Running Backup...
@echo off
C:
cd \epic51\progress\bin
vntgbkup online C:\epic51\vantage\db\vantage C:\backup\backup.1
you can probably modify this to backup to a different location and just run it. The prorest it to the new DB location
vntgbkup.bat in the progress\bin folder in turn runs the actual backup commands for online or offline backup. One note - when I converted from 4.0 to 5.0, 5.1 and 5.2 somewhere along the way it did not correctly name the EPICxx folder in the batch command files so I had to double check them to assure they were referencing the correct places.
Hope this helps,
-Todd C.
Sent: Sunday, April 06, 2003 10:04 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] 5.1 to 5.2 (live buckup, conversion)
Hi,
I'm in the early stages of upgrading from 5.1 to 5.2, I have 5.2 running
on a new server and I was wondering if there were some instructions on how
to do a live backup on 5.1 so I don't have to stop 5.1 and production and
then move the backup to the new server and convert to data into 5.2
In the instructions it assumes you can stop the 5.1 data base and also
assumes that this is all done on the same server. I do recall back in the
version 4 days you could do a live backup and convert to the latest version
of vantage on any server the the instructions were pretty easy to follow
Mark Howard
Financial Controller
Jaws Buckets & Attachments
This email, together with any attachments, is intended for the named
recipient(s) only and may contain privileged and confidential information.
No information within this email can be forwarded via email or verbally
without the consent of the sender.
If not an intended recipient of this email, you must not copy, distribute or
rely upon it and any form of disclosure, modification, distribution and/or
publication of this email is prohibited.
Unless stated otherwise, this email represents only the views of the sender
and not the views of Jaws Buckets & Attachments.
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/M=249982.3083889.4452939.1728375/D=egroupweb/S=1705007183:HM/A=1524963/R=0/*http://hits.411web.com/cgi-bin/autoredir?camp=556&llineid=3083889&prop=egroupweb&pos=HM>
<http://us.adserver.yahoo.com/l?M=249982.3083889.4452939.1728375/D=egroupmail/S=:HM/A=1524963/rand=334708707>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
@echo off
C:
Hope this helps,
-Todd C.
Hi,
Mark Howard
