Open edge -Data admin
Thanks and yes I have 803.400D
--- In vantage@yahoogroups.com, "charles06072006" <shadow031449@...>
wrote:
> Openedge has only one user (sysprogress) installed as the default.
> That user has access to everything and is also the data admin. You
> can add other users using the OpenEdge data administrator, however
> the added users will not have any authority to the tables. You will
> need to use Progress Explorer to grant the necessary rights to those
> users. In fact Progress Explorer can be used to add the users as
> well. Support has the necessary documentation to guide you through
> this as well as a file that helps to grant authority to the tables.
> Just ask for documentation on how to add ODBC users.
> This is dependent on you running 8.03.305x. If you are running
> 8.03.400 with the new 10.1b Openedge, the Progress Explorer function
> has gone away. I have not found a way to get around that.
> --- In vantage@yahoogroups.com, "kirsty2179" <dobby01@> wrote:
> > Having problems uploading crystal report, seems the problem is the
> > user ID within open edge- data administraation. Dose anyone no how i
> > chages this?
> > regards
chages this?
regards
> chages this?
> regards
We have 10.1b OpenEdge with MS SQL on our Vantage 8.03.403d Server. Progress Explorer is still there and shows the AppServers and Databases as before on 10.0b OpenEdge.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, January 24, 2008 4:48 AM
Subject: [Vantage] Re: open edge -Data admin
> chages this?
> regards
Yahoo! Groups Links
