OT: Proxy and Dial up Networking / XP Client in an NT Domain
This worked! Thanks. We were disabling the proxy in Internet Explorer
but for got about WPS Client in the Control Panel. Thanks a lot for
your help!
Juliet
Sent: Friday, September 27, 2002 3:39 PM
Subject: [Vantage] Re: OT: Proxy and Dial up Networking / XP Client in
an NT Domain
Also go to the control panel and disable the Win Proxy Client. Both
the IE check box and the Proxy client have to be disabled for it to
work.
--- In vantage@y..., "Juliet Martin" <jmartin@r...> wrote:
> I have unchecked it and it still doesn't work. I am at a loss. I
will
> keep looking. If I find anything I will post it to the group.
> Juliet
> From: Peter [mailto:peter.paasch@a...]
> Sent: Friday, September 27, 2002 2:55 PM
> To: vantage@y...
in
> an NT Domain
> The user has to disable the proxy client when he is not using the
> proxy server. In the tools internet options LAN setting of IE.
Make
> sure the use proxy server check box is off. I haven't used Proxy
> server 2.0 for a while now (ISA Sever) but if there is proxy
client
> installed you will have disable it to get on the internet at home.
> > Second question:
> > Microsoft Proxy 2.0
> > The person has a laptop connected to our network. When he takes
it
> home
> > he can't get on the internet using his dial up. Everything seems
> to be
> > set up correctly. Like I said - If I set up the DUN first I can
> connect
> > to the internet using his home account. Once I load proxy I can
> only
> > get connected while I am on the company network. I can't get the
> dial
> > up to function anymore.
> > Juliet
> > Sent: Friday, September 27, 2002 2:44 PM
> > To: vantage@y...
Client
> in
> > an NT Domain
> > A couple of questions. You stated you have two domains but you
> > dicribed your computers as one PDC and one BDC. Each domain
needs
> at
> > least one PDC. What is the exact error when you log in? Check
the
> > event log for Error numbers.
> > Your other question. Yes they can exsist on the same box. A
proxy
> > works by passing data that the proxy recieves from a port number
> like
> > 8080 on Lan you a connection not on you LAN. That connection can
> be
> > anything. Modem or High-speed. So which box do you dail up the
> > internet with 98 or XP? What is your proxy server software?
> > > I am sorry for 3 off topic questions in a week but I have no
one
> > else to
> > > turn to. If anyone has any crumbs they could throw my way I
> would
> > be
> > > forever grateful.
> > > In experimenting with DUN and Proxy server on a Win98 and a XP
Pro
> > > client I have noticed that I can have DUN working then when I
> load
> > the
> > > Proxy Server Application so the user can get the internet on
our
> > network
> > > - DUN no longer works (I have Proxy turned off, etc, etc). Can
> the
> > two
> > > co-exist on the same PC? I have been searching on the internet
> for
> > over
> > > an hour and have not come up with anything conclusive.
I am sorry for 3 off topic questions in a week but I have no one else to
turn to. If anyone has any crumbs they could throw my way I would be
forever grateful.
In experimenting with DUN and Proxy server on a Win98 and a XP Pro
client I have noticed that I can have DUN working then when I load the
Proxy Server Application so the user can get the internet on our network
- DUN no longer works (I have Proxy turned off, etc, etc). Can the two
co-exist on the same PC? I have been searching on the internet for over
I got a new PC's for three individuals at our Company. The new OS is XP
Pro. Their old OS's were NT and 98. I have two domains on our network
one that has two Windows 2000 Servers (BDC), the other domain (the one I
want them logging into - the PDC) has a NT Server. If they log into the
2000 Domain the computer has no problem. If I log them into the NT
Server I get a bunch of errors that the PC can't find their local
profile on the network and any changes to their profile will be lost.
We don't have roaming profiles. One of the individuals had profile
settings in their home directory and I deleted it (user.dat). I then
deleted their profile folder on the XP client. I thought that maybe it
would be recreated. No luck. I don't know what else to do.
TIA,
Juliet
dicribed your computers as one PDC and one BDC. Each domain needs at
least one PDC. What is the exact error when you log in? Check the
Your other question. Yes they can exsist on the same box. A proxy
works by passing data that the proxy recieves from a port number like
8080 on Lan you a connection not on you LAN. That connection can be
else to
be
> forever grateful.
the
network
two
over
is XP
network
one I
into the
lost.
then
maybe it
> TIA,
> Juliet
First Question:
I will check the event log and get some numbers to look up and exact
error message.
Second question:
Microsoft Proxy 2.0
The person has a laptop connected to our network. When he takes it home
he can't get on the internet using his dial up. Everything seems to be
set up correctly. Like I said - If I set up the DUN first I can connect
to the internet using his home account. Once I load proxy I can only
get connected while I am on the company network. I can't get the dial
Juliet
an NT Domain
else to
be
> forever grateful.
the
network
two
over
is XP
network
one I
into the
lost.
then
maybe it
> TIA,
> Juliet
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
proxy server. In the tools internet options LAN setting of IE. Make
server 2.0 for a while now (ISA Sever) but if there is proxy client
> First Question:
> error message.
> Second question:
> Microsoft Proxy 2.0
home
to be
connect
only
dial
> Juliet
> To: vantage@y...
in
> an NT Domain
at
like
be
> else to
would
> be
> > forever grateful.
load
> the
> network
the
> two
for
> over
OS
> is XP
> network
(the
> one I
> into the
NT
> lost.
profile
> then
> maybe it
> > TIA,
> > Juliet
must
access. )
Builder
I have unchecked it and it still doesn't work. I am at a loss. I will
Juliet
an NT Domain
> First Question:
> error message.
> Second question:
> Microsoft Proxy 2.0
home
to be
connect
only
dial
> Juliet
> To: vantage@y...
in
> an NT Domain
at
like
be
> else to
would
> be
> > forever grateful.
load
> the
> network
the
> two
for
> over
OS
> is XP
> network
(the
> one I
> into the
NT
> lost.
profile
> then
> maybe it
> > TIA,
> > Juliet
must
access. )
Builder
work.
will
> Juliet
> To: vantage@y...
in
> an NT Domain
Make
client
> > First Question:
exact
> > error message.
> > Second question:
> > Microsoft Proxy 2.0
it
> home
> to be
> connect
> only
> dial
> > Juliet
> > To: vantage@y...
Client
> in
> > an NT Domain
needs
> at
the
proxy
> like
> be
one
> > else to
> would
> > be
> > > forever grateful.
Pro
> load
> > the
our
> > network
> the
> > two
> for
> > over
> OS
> > is XP
> > network
> (the
> > one I
> > into the
the
> NT
local
> > lost.
> profile
I
> > then
> > maybe it
> > > TIA,
> > > Juliet
> must
> access. )
> Builder
must
access. )
Builder
