I just checked a poweredge 350 and in the bios under Boot there is an option
for What to do after a power failure and "turn on" is the option I have.
you may want to double check. I have a 1650 and I'll check it later for
you. However, and this is just a thought....do you have your UPS gracefully
shutting down the server (ie a serial cable to power down when the battery
fails?) Perhaps the system doesn't think it is a power failure but just a
shutdown and therefore doesn't turn itself back on. Like I said I may be
all wet because I've never had to test it. I'll let you know if my other
Dell has the same Bios.
Good luck.
Jim Carnes
Information Systems Administrator
jcarnes@...
Kenlee Precision Corporation
1700 Morrell Park Ave
Baltimore, MD 21230
Sent: Wednesday, April 07, 2004 2:41 PM
Subject: [Vantage] OT: Shutting down server in the event of a power
failure
Well got a good one for you
We have a Brand spanking new DELL 2600 Power Edge Server
It is attached to a Tripplite SU2200 100VA Battery Backup unit
I am running Windows 2003 Server
Latest version of Power alert software
We had a power outage this weekend. (First time since putting in the new
server)
The server did not come back online when the power was restored
The old Vantage server did (HP LH3000)
Called Tripplite
They said its a Dell issue as all my settings were correct
Said there is a BIOS Setting that tells the system what state to return to
in the event of a power outage
REbooted the server over lunch today
No Setting
Called Dell
No setting available in BIOS/CMOS for this
This is a software issue
Their recommendation, call Tripplite!
Called Tripplite - They say Dell is nuts and that if there is no setting
in
CMOS for this then I am S O L
Anyone have a solution for me?
The power management built into Windows 2003 only lists a APC Unit and I
searched Microsoft's website for a drive without any luck!
James Piper
Meco Inc
Paris IL
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Good luck.
Jim Carnes
jcarnes@...
Baltimore, MD 21230
failure
server)
Called Tripplite
No Setting
Called Dell
in
James Piper
Meco Inc
Paris IL
ADVERTISEMENT
Yahoo! Groups Links
