You may want to try connectin the printer to an NT workstation and see if
that affects performance, or at least a different 98 workstation.
Also make sure that all the workstations are using the same network protocol
settings. Using NetBEUI may slow things down if you're using it. We use
just TCP/IP, ever since we sent the old Novell box to the attic.
As one of the users mentioned, getting the printer hooked directly to the
network using a little print server box could help as well.
Try checking any differences in the windows print settings between the
default Windows NT and Windows 98 driver installations. Try experimenting
with different spool settings and spool data formats (RAW, EPS, PMJOURNAL,
ETC...)
Please let me know what the results are.
Best Regards,
Thaddeus
Sent: Friday, May 11, 2001 1:57 PM
Subject: Re: [Vantage] (OT) slow printer
It's directly connected to a 98 computer then everyone else is sharing the
printer from that computer.
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
ETC...)
Best Regards,
Thaddeus
Wendy Bowen
wpursche@...
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, May 11, 2001 2:46 PM
Subject: RE: [Vantage] (OT) slow printer
> Is this a direct connect between the PC and the printer via LPT port or
> From: Wendy Bowen [mailto:wpursche@...]
> Sent: Friday, May 11, 2001 1:30 PM
> Subject: [Vantage] (OT) slow printer
> We just purchased a HP DJ932c. For some reason it takes a VERRRRRYYYY
long
> time for a computer with NT 4.0 to print to it. Win 95 & 98 print with a
> good speed. I have downloaded, numerous times, the drivers from the HP
site
> hoping that I just had a bad driver. I have uninstalled and installed the
> drivers. I have rebooted the computers. No luck. It doesn't matter what
> software I'm printing from either, Word, Excel, MasterCAM, Vantage, or a
> standard text file. I'm really at a loss for this one. Any ideas?
> Thanks!
> Wendy Bowen
> wpursche@...
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
