Either. With a BAQ you would summarize your chosen period bucket totals in a BAQ report.
You can also do it via SQL out of excel or a web page. I'd be leary of that though as hitting a huge table like parttran w/ SQL may result in system load issues (slowing down user apps).
--- Original Message ---
From:"michael.hutcheson@..." <michael.hutcheson@...>
Sent:Fri 7/2/10 11:01 am
To:vantage@yahoogroups.com
Subj:[Vantage] Re: Part history usage
would this all be possible using a BAQ or will I have to use crystal?
--- In vantage@yahoogroups.com, robertb_versa@... wrote:
> Parttran is what you want. Just filter on the types pertinent to you. You can also get fancy & seperate independent from dependent use based on type. How you choose to bucket summarize (quarterly, monthly, weekly) is up to you.
> Sent:Fri 7/2/10 6:51 am
> Subj:[Vantage] Part history usage
> Hey folks,
> I'm building a report to show the part history usage - qtys used in the past 6 months etc. Is it just a case of using the part tran table, filtering for tran types and dates or is there another way?
> Regards,
> Michael
