Same here, GParted has always worked on our NTFS partitions with no problem,
but we don't use compression. If you need to change a NTFS partition with
compression then I'd recommend using Microsoft's DiskPart.exe. As long as
the drive isn't the boot drive, you shouldn't need to boot into a special
mode. If it is, I've used Bart's PE Builder to make a boot CD. Not as
easy as a Ubuntu LIveCD.
Randy
_____
jonnyfatman666
Sent: Thursday, February 15, 2007 6:40 AM
Subject: [Vantage] Re: Partition magic
I'll put in another vote for GParted. I've used it on plenty of PCs
without problems, but never on a server. It seems a pretty stable
product but remember it won't deal with NTFS compressed partitions.
As long as you're properly backed up, then give it a go!
Jonny
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, Wayne
<wmc20@...> wrote:
owned it) to a poorly supported and marketed piece of junk that
trashed 70% of the NTFS partitions I tried it on. Symantec seems to
have lost all interest in the product, but will still take your money
if you want to waste it downloading it. Don't bother.
Randy
_____
jonnyfatman666
Jonny
<wmc20@...> wrote:
>on
> Todd Anderson wrote:
> > Does anyone know of a package like Partition Magic that will run
> > MS-2003-Srv?sourceforge.net/
> Gnome Partition Editor http://gparted. <http://gparted.sourceforge.net/>
> It's free open-source.tried it, it had deteriorated from a great product (when Power Quest
> The Symantec product mention *IS* Partition Magic, and last time I
>[Non-text portions of this message have been removed]
> -Wayne
