We are still running 3.0, so I passed this information on to our Finance
Manager since I knew she was getting ready to run W2's. After about a
day of analysis, she found that if you go back and rerun the quarterly
tax reports, it shows the amount to be corrected. In other words, the
reprinted quarterly reports varied from the original ones printed
earlier in the year. The W2's came out correct. Has anyone else
discovered this too or did we miss something else?
Marilyn Fairchild
Pickwick Manufacturing Services
Sent: Friday, January 12, 2001 4:29 PM
To: vantage@egroups.com
Subject: RE: [Vantage] Payroll bug! Affects W2!!!
I just got done checking 3.0 and this problem exists there as well.
for the heads-up, Joe.
Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty St. Ext.
Meadville, PA 16335 814-333-6331 x236 fax: 814-337-2548
tlw@...
www.chipsco.com
Sent: Friday, January 12, 2001 2:13 PM
To: 'vantage@egroups.com'
Thanks for the update.
Sent: Friday, January 12, 2001 1:57 PM
Subject: Re: [Vantage] Payroll bug! Affects W2!!!
We are on version 4 with the 904 patch. We caught this by
reconciling the 941 taxes to the taxes in the "earnings
report" and the "quarterly tax report".
"Wilmoth, Deb" wrote:
Do
(Note: If this link does not work for you the first time you try it, go
to
www.egroups.com, login and be sure to save your password, choose My
Groups,
choose Vantage, then choose Files. If you save the password, the link
above
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password,
the link above will work the next time you try it.)
Marilyn Fairchild
tlw@...
www.chipsco.com
>totals?
> Joe, did you find the error in reconciling 941 totals to the W-3
Do
> you reconcile Vantage to a manual spreadsheet? Or how did you locatethe
> problem? Are all versions of Vantage going to have this problem?[Non-text portions of this message have been removed]
> Deb Wilmoth
> Reeder & Kline
> From: Joe Konecny [mailto:jkonecn@...]
> Sent: Friday, January 12, 2001 1:17 PM
> To: Vantage List
> Subject: [Vantage] Payroll bug! Affects W2!!!
> Just found out today that there is a bug in payroll
> that affects W2's.
> If you void a check in a period other than what the original
> check was posted the total taxable wages will be incorrect.
> Only fix is to manually edit the W2's. Tech support confirmed
> this and said there are no plans to fix it.
to
Groups,
above
