Regarding the changes not saved - I had a similar problem with another
screen. I called tech support and found out that for any customizations
you make, you have to save a valid record to actually save the changes.
Here's the workflow:
Open the form
If there is a record already created, load it
Right click on the form and select customize
Save all frames
Exit customization
Select OK to save the record and close the form (this is what actually
saves your customization)
I still had a problem with a form where I could not make multiple
changes to the form. I had to make one change, save it, go back in,
make another, save it, etc.
Butch
Sent: Friday, October 15, 2004 9:06 AM
Subject: [Vantage] Personalization in 6.1 - PO Line Entry Screen Tuning
All,
Since I have 3 users that bang away at Purchase Order Entry and Editing
all
day I thought now that I was on 6.1 I could performance tune our
purchase
order entry screen by setting tab stops on the fields we update instead
of
tabbing thru part description, part advisor button, release delete
button,
release close button, release reopen button, help button, substitute
button,
cancel button, etc.... well you get the idea.
I finding even after personalizing and saving all frames and pressing OK
on
the record line being edited to make sure changes get save, that changes
in
tab order are not saved.
If I uncheck fields for "Tab Stop" to take them out of the list:
Warning "** Attribute MOVE-AFTER-TAB-Item for the BUTTON ASM-BTN
was
passed an invalid widget. (4062)
If I change the programs first tab stop:
Warning "** Unable to set attribute First-Tab-Item for FIELD-GROUP
widget. (4078)
I could try customization but its not available in all programs like PO
line
entry.
Has anyone had luck changing the flow thru Purchase Order Line Entry?
Patrick Winter
sSc Specialty Screw Corporation
Vantage 6.10.514, Progress 9.1D08, Windows 2003 Server, Crystal
8.5.3.975
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129b7l1iv/M=315388.5497957.6576270.3001176/
D=groups/S=1705007183:HM/EXP=1097942813/A=2372354/R=0/SIG=12id813k2/*htt
ps://www.orchardbank.com/hcs/hcsapplication?pf=PLApply&media=EMYHNL40F21
004SS>
<http://us.adserver.yahoo.com/l?M=315388.5497957.6576270.3001176/D=group
s/S=:HM/A=2372354/rand=706016462>
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Open the form
Save all frames
Exit customization
Butch
All,
all
purchase
of
button,
button,
on
in
was
widget. (4078)
line
entry.
Patrick Winter
8.5.3.975
ADVERTISEMENT
click here
004SS>
Yahoo! Groups Links
