PO Form Ship To Address
When I print a PO in Epicor 10, it appears that, whenever any of the lines on the PO are tied to drop ship releases, it prints a separate address for each PO release and puts “{ See Below }” in the header box.
It does this even if the ship-to address is the same for all of the releases, which can clutter the report with a lot of repetitive information. Is there any way, in this case, to have the address display in the header box?
On the PO Form, the Header ship to address is a calculation as is the po release ship to address,
The only way I know is to go in and edit the calculations to get what you want.
Brad Boes
bradboes@boosterpconsulting.com
231-845-1090
That’s what I figured. I modified the report form to display the information the way I needed it.
@BoostERP @dmmory, I second Brad’s suggestion. I just re-did the PO Form and was confused by this as well. We just rolled with it though.
