PODetail Inspection Required Epicor version 604
I want to be able to inspect a part on receipt and not have to tick the RcvInspectionRqd box on Part Class or Supplier or manually tick the Inspection Required box on a PO.
The PartPlant table has a RcvInspectionRqd field but it doesn't display on the Part Menu. However I have managed to set this field to true using DMT. I have then tried to look at this field and if it is true change the PODetail field to true using a method directive and ABL Code but can't seem to get it to work
Can anyone help with this?
Adrian
